Air cleaner duct???
Old 12-10-2016, 04:36 PM
87Z52
87Z52's Avatar
Default Air cleaner duct???
Reinstalling the air cleaner in the Grand Sport and I guess I tightened this clamp a bit too much. I can't find just the clamp; only the entire duct and with shipping it's close to $100. All I need is the clamp...any ideas where to get it separately? Or maybe a used duct?
Old 12-10-2016, 04:45 PM
87Z52
87Z52's Avatar
Maybe answering my own question but what about trimming off the rubber tabs that hook into the clamp and then just sourcing a "normal" hose clamp of the correct size? Any down side to that?
Old 12-10-2016, 04:47 PM
extrapilot
extrapilot's Avatar
I would think you should not have a problem with any auto parts store and picking one of the correct size worm gear clamp.
Old 12-10-2016, 05:08 PM
Not So Fast
Not So Fast's Avatar
None that I see I would do it instead of a $100 new one that's for sure
NSF
Old 12-10-2016, 05:11 PM
Welker1
Welker1's Avatar
NSF
You can pick up a new clamp for a couple dollars at most auto parts stores or hardware stores
Old 12-10-2016, 05:28 PM
87Z52
87Z52's Avatar
Thanks guys! Regular clamp definitely seems the route to go. Cute little duct/clamp interlocking design they had but geez. Over engineering at its finest. This isn't a German car right?
Old 12-10-2016, 05:29 PM
oemtech
oemtech's Avatar
Get a silicone coupler (red, blue, black ?) & a couple of nice SS clamps. Fixes the problem & adds some bling.
paulrichy (12-10-2016)
Old 12-10-2016, 05:41 PM
sevinn
Support Corvetteforum!
sevinn's Avatar
St. Jude Donor '14, '16
Smooth out the nubs (if you really want to) then go get a hose clamp made for a dryer vent.
Old 12-10-2016, 05:48 PM
A Marsh
A Marsh's Avatar
That's what I did on a previous car I had.
Old 12-10-2016, 05:57 PM
BlindSpot
BlindSpot's Avatar
Received 1,368 Likes on 907 Posts
Do this, Ebay.
Old 12-10-2016, 06:55 PM
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
There's probably a reason for the rubber tabs, but the only one I can think of is so they can charge an owner $100 for a new part that should cost about $5 -- or well less if you only have to buy the clamp.
Old 12-11-2016, 09:10 AM
87Z52
87Z52's Avatar
Old 12-11-2016, 09:50 AM
GREENKAR
GREENKAR's Avatar
You might give Vettenuts a try. They sell used items off of wrecked vettes. They are a vendor here. Very
Old 12-11-2016, 11:25 PM
mikeCsix
mikeCsix's Avatar
This is the best answer.. Changing the hose to a smooth walled hose will change the airflow characteristics and may create issues with the MAF.
Old 12-11-2016, 11:52 PM
owc6
owc6's Avatar
Received 4,191 Likes on 2,681 Posts
If all that is broken is the clamp, any hardware store should have one. They're the same size as dryer vent clamps.
The rubber nubs are just to keep the screw in the most convent place (up top) to tighten or loosen.
Old 12-12-2016, 04:20 AM
Don-Vette
Don-Vette's Avatar
It's a hose clamp,put a new one on. I love "rocket science"!! Lol
Old 12-12-2016, 08:43 AM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,845 Likes on 1,802 Posts
It won't bother the MAF.
To Air cleaner duct???
Old 12-12-2016, 11:10 AM
oemtech
oemtech's Avatar
Nahhhh... If anything it will improve the air flow.
Old 12-12-2016, 03:01 PM
ALS 08
ALS 08's Avatar
$2 at any plumbing store
Old 12-12-2016, 08:55 PM
cclive
cclive's Avatar
If I were overthinking this, I would go to the ends of the earth to get an oem hose clamp. 40 years from now, when they are no longer available, a guy from the NCRS will deduct points for having the wrong one.
Quick Reply: Air cleaner duct???
