Connecting Battery Tender
I just purchased a Black & Decker 2A battery tender and it came with three different hook ups, aux power plug (cigarette lighter) "O" rings and the standard battery cable clamps.
My intentions are to use the aux power plug but if for some reason I should opt to use the standard clamps is it best to use the recommended alt. battery lugs for jumping off or can they be connected direct to the battery without fear of damage or explosion.
I'd use the terminal on the side of the fusebox and a ground on the right frame rail.
If you want to hook up the clamps directly to the battery, you can.
Better option would be to hook up the O-Rings to the batter and you can plug the tender into that. That's how I had my 2005 setup. On my 2013 I use the cig lighter.
Received 4,734 Likes
The clamps and lugs do the same thing but both require getting under the hood. This is fine if the car is not driven often or driving it is a special event that you prepare for. Using the cigarette lighter plug is easy and works the same. No getting under the hood, I just reach in and unplug from the console and drive away.
I use the cigarette lighter on mu '05.....works great. Since we had such a mild winter last year I got to drive it often. The lighter was quick and easy to connect and disconnect.
If you look on the bottom of the door opening there is a slot that is just right for the battery tender wire. Ctech makes an awesome battery tender made for the corvette.
O rings is how mine is set up. Lower the hood down to where it just rests and not close all the way. Been doing that 3 years without a problem.
I like using the alligator clips and connecting directly to the battery (positive cable). I connect the negative clip to a good ground (like an exhaust manifold bolt).
Steve
Steve
I have that same tender, I dont drive the car often i did the O-ring method!
As the name implies the are two connectors that are just that "O" rings. You have a positive one and a neg. one and they connect to the battery accordingly. Just remove the nut from each battery cable and put the O ring on and put the nut back on. Then when you are ready to go you just disconnect the cable at the inline plug in point, leaving the O rings in place and you are ready to go. Replug when you return and you all set. The O rings are left in place permenantly.
My battery is in the trunk. O rings connected to the terminals. When not in use I disconnect the cord and stuff into the battery compartment and close it. When in use I run the cord where two pieces of weather stripping meet and close the hatch without a problem.
