off button for heated seat stopped working
on my 2008 the driver's side off button for the heated seat just stopped working. I have to turn the car off to get the heated seat light to go out.
not a big deal, but I wanted to know if anybody else had this problem and what they did to fix it before I start troubleshooting.
thanks.
thanks.
Had this problem also, happen once and did not repeat again so far.
I would imagine that the issue is with the controlling module, I believe is located under the seat.
theblue (10-14-2016)
The buttons may be sticking. All of my plastic buttons stick in the on position sometimes. The dic buttons, the ac controls, the heated seats. I put a shot of silicon lubricant spray around them and they stopped sticking.
I can press it and it moves normally like the others.. might try that anyway just incase. thanks
First thing to do is pull the switch and check continuity with a meter. If it's OK, then likely it is damage to the connections under the seat, especially if you move the seat often.
