Anyone try Plasti dip?
On their wheels? I want to know how it is lasting? How hard to remove?
Anyone try any other methods. I'd like to hear pros and cons of specific brands.
Thanks,
Rob
Thanks,
Rob
It is easy to remove if you apply several coats. The more you apply, the easier it'll be to peel off later on, plus it'll be thicker too which will allow for more abuse from rocks and other stuff flying around. Only tried the original stuff and it did what I wanted, to change wheel colors relatively easy and fast.
easy to apply and take off, but looks absolutely LOUSY when brake dust gets on it, it turns a dreadful brown color and its annoying to remove due to texture at times, this is even when applying many coats of the glossifier. I dyno my car relatively often and when strapping down on the dyno it comes off due to the rubbing on the straps which is annoying especially when driving home
not a bad product but I'll just buy black rims next time
I'm with him ^^^^^
While some think it looks great, I beg to differ. No luster, shine, or sparkle. It leaves a very dull look, and I've also found it can be extremely difficult to remove. It's a fad that some try because it's a fad.
youtube and google is your friend on this one. there are TONS of options and different ways they can make it look more metallic etc. at the end of the day it peels blisters and looks cheap to me. if you're looking for a cheap couple month change that looks tolerable from 10 feet away its ok but its not a permanent or show winning result. Also if you change tires it will certainly rub it right off the bead of the wheel so know that as well.
I used it on my rims just to see if wanted to buy black rims in the future, cheap alliterative. I remove it after one season, I didn't get the gloss I was looking for. I recall it wasn't that easy to remove.
I work with 800 other people. Parking lot full of cars. Some of them with plastidipped wheels. It looks... Like pastidip. And for your own sanity, do NOT use any kind of standard automotive clearcoat. Or you'll be chipping away at it for months trying to remove it. And the Glossifier is NOT a clearcoat. at best, it gives a satin finish.
you're not applying the glossifier right. My wheels were plastidipped gold (6 coats with 3 coats glossifier) and they definitely weren't dull or satin. I wouldn't say it was comparable to an automotive clearcoat gloss but they looked good. The brake dust was terrible, but it was terrible with my chrome wheels too though. I just got bored and peeled it off the other day after 3 months on. Pretty cheap option to have a different look and as long as you apply it right, its not that hard to remove.
Mine never faded, it just turned brown because of all of the brake dust, its pretty easy to clean plastidip with glossifier , but nowhere near as easy to clean actual rims with a nice clearcoat to them.
plastidip is more of an eggshell finish but with the glossifier its a satin finish, no matter how hard you try, you will never get the beautiful shiny look of a black glossy rim, plastidip also has a mild texture to it and dust LOVES sticking to it.
I used plastidip as a proof of concept and I don't regret it because it cost a grand total of maybe 20$, but at the end of the day a nice glossy rim looks lightyears ahead of a glossified plastidip rim
If I want "Black Wheels" they will have to be shiny which cannot be accomplished with Plasti-Dip, I have experimented with it.
The finish looks Ok with Glossiifier but it is satin at best.
There is product DYC sells called Brake Dust Pro (see it on You Tube) that is a spray-on cleaner that washes away brake dust without scrubbing, does pretty well also, but costly with S&H.
I have done quite a bit of Plasti-Dip but with wheels its not my thing, other stuff its great
Good luck
NSF
Good luck
NSF
I've used plasti dip on truck emblems before and it looked ok, but when I see it on wheels it just never really looks right, or black to me. Kinda always has a dry grey look to it and I'm also not a fan of matte black wheels I prefer glossy so it kinda reminds of of a grey matte black wheel. It is good to use tho if you want to at least see how your car will look before purchasing black wheels.
you can get almost any color you want with plasti dip these days.
I used several layers of plastidip on my fx35 wheels as a base layer then sprayed them with normal metallic paint on top. Still kept the peel-ability and the top layer was regular gloss metallic paint. I tried it temporarily to see if i wanted black wheels. Pretty easy and reversible if it goes wrong
I have had mine plasti dipped for over a year with glossifier. Every time I clean my car I use armorall extreme tire shine on them to gloss them up again. Be careful though some types of tire shine will eat the plasti dip. I also did a light coat on my tail lights.
At least I know how to use the search feature. A simple search for "plasti-dip" would turn up some of the many, many, MANY threads on the subject.
That chip on your shoulder is going to give you back problems. Might want to downsize it a bit, and get some thicker skin while you're at it. My original comment was a joke; get over it.
Geez....some people these days have no sense of humor....
I got a great sense of humor btw. The thing is most people when they make jokes they say something after so we know you are joking and actually give a reasonable answer. And btw I thought forums were for people to ask questions to get information on their cars and not FAQs that you only can look up with no questions. I apologize for not knowing everything about the C5.
Check out their web site. They have some great looking wheel kits. I do believe a few years back when it first hit teh market, the standard black did not go well as it did stay dull and would never make people say boy those look nice, but with all the new wheel kits they have I think you can get teh look you want.
