Cable in glove box
Cable in glove box
Hi everyone,
Just got a C6 ZR1, there is this cable in the glove box. iPod? I don't know what it's for. Wondering if I could get an Auxillary Plug adapter for it?
Thanks for your help!
Received 2,898 Likes
Retired & lovin' it!
Definitely not OEM. Best bet is to try to contact the original owner to identify. Certainly could be for some personal device that was used in the vehicle.
ZoeDuc (09-01-2016)
Received 1,597 Likes
Looks like an ipod connector.
I bought the car at a dealer, so I can't ask the previous owner.
I think I'll just take it to an audio place, but I wanted to ask you all first.
If you have any teenage relatives just ask them. Seriously, they will even be able to tell you what model ipod it is for.
Do you have an aftermarket radio?
It is the 30 pin used by the gen4 and earlier iphone/ipod. The item you pictured will work unless you have a case on your phone. With a case you will need one of this. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
ZoeDuc (09-01-2016)
Not sure how many pins it is; had the Kenwood & the adapter installed a few years back and all I recall is that I needed the iPod adapter cable installed versus just the USB extension cable if I wanted to use an iPod...sorry
ZoeDuc (09-01-2016)
yes .....as long as it is an APPLE adapter as the knockoffs do not work , I used one on my ISIMPLE when I had it
what you will have to figure out is how to you access the input
is it thru XM2 menu or some other means ....
ZoeDuc (09-01-2016)
That looks exactly like the GM PAL cable that I had in my old 2008. The GM PAL tied in to the factory radio (i had factory NAV) and you accessed through the XM2 menu on the radio. Once you plug in an ipod or iphone, you can control it through the radio. It was pretty slick for 2008.
ZoeDuc (09-01-2016)
The following 4 users liked this post by ZoeDuc:
