Early model?
Early model?
I traded my 03 for a 08 at a Dealer yesterday!
I think that this is a very early model 08 as the serial number is 100006 and it was delivered to GM at Warren Michigan. According to the build sheet, it was built 4-24-07 Black Convertible, 3LT, Power Top, Z51, NAV, NPP
I googled the serial number today and my car shows up. I googled all of the numbers in my cars range 1 through 10 and mine is the only one to show up? Am I wrong in assuming that the first numbers and letters would be the same? In my case my full VIN is 1G1YY36W685100006. I went on assumption that only the last 6 digits change?
Received 1,681 Likes
Congrats! Now is when you should post a picture of the new car!
lwise4 (08-13-2016)
Congrats on the new car- the low serial numbers typically receive greater quality control scrutiny.
You can always post a picture of the options sticker on the glove box door if you'd like help decoding the options.
I actually have a copy of the window sticker and it shows no NPP.
I will keep digging.
Received 3,715 Likes
2016 C6 of Year Finalist
Curiouser and curiouser...probably doesn't add much value but certainly cool!
lwise4 (08-13-2016)
Received 4,523 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Wow, perfect color, and someone is going to enjoy the summer, with wind blowing though your hair, don't burn from the sun.
Nice car!
lwise4 (08-14-2016)
I stopped at the Dealer yesterday and got a copy of the "BUILD SHEET" as suggested by another member. I have attached a copy. This is indeed a early car!
Very cool build sheet. Nice to know you have "antenna diversity"...
Did anything odd show up on the VIS "Vehicle Report"?
I replaced the fuse but it still is not working. I looked under the back end this afternoon and found that a hose was off one of the actuators. I put it back on and started the car but it still had both actuators open.
I ordered a mild to wild kit so I will wait for it to come in to dig deeper in to the problem.
