Fob only works partially. Battery good.
I have read a number of threads (sticky and otherwise) about the dreaded "no fob detected" message.
Here is my situation. The fob works fine to open the doors and trunk, and also works fine when inserted in the glovebox slot. Furthermore, it works fine to start and shut off the engine if I hold the fob an inch or two from the start button. However, it will not work any farther away than that, whether in or out of my pocket.
I have replaced the battery three times, with two different brands, but the problem persists. I also bent the contact tabs up, although I haven't yet tried bending in the three tabs that hold the battery. Could that be it? BTW, every time I open the fob, the battery holder pops loose, with the battery still inside. Is it supposed to be attached to the fob case? It seems to just sit loosely in its recess.
I can't believe it is just a weak battery, since I'm now on my fourth one, counting the original. I might take it to Radio Shack and have it tested, but wanted to ask here first.
The antenna that verifies the valid fob for starting is in the glove box, so holding the fob near the start button doesn't quite make sense, unless the "inch or two" from the start button is close enough to the glove box to register. Have you tried pulling it away from the start button, but putting it closer to the antenna, rather than back or to the left?
If this works, it may be a step toward figuring out exactly what is going on.
the kid C6 (08-04-2016)
Thanks.
Sorry, I should have mentioned that I did indeed try the other fob, and the same thing happened. However, I only replaced the battery in fob #2 once.
I think you can rule out the fobs. Either the car receiver/antenna(s) have a problem or something is generating interference. Have you tried removing every portable electronic gizmo from the car and your person? If you drive to another location, do you still have the problem?
It happens at various locations, but it does not happen all the time.
Makes me almost yearn for the old days and those metal keys.
Bruze (08-04-2016)
Bruze (08-04-2016)
Received 1,136 Likes
Downside: Another layer of electronic complexity that can go haywire at any moment and leave you stranded. The creed of the nerds: "We do it because we can."
Metal key upside: They work flawlessly and reliably for thousands and thousands of times.
Downside: You have to take it out of your pocket.
A question: How many posts are there on C5-6-7 forums about fob problems?
How many posts are there on older Vettes about key problems?
Perhaps, but I've had to replace the key assembly on more than a few cars over the years, some of which left me stranded. I've never been stranded due to the fob. I've been confused early on, but not stranded.
Old school is not necessarily better.
The advantages of the following technologies should be obvious; the downsides, if any, are minimal:
Electric lights vs. candles and kerosene lamps.
Hot and cold water outlets at various places in the house vs. walking out to a well.
Indoor flush toilets vs. outhouses.
Traveling by car vs. traveling by horse.
Air conditioning.
Gas or electric cookstoves vs. wood cookstoves (especially in the summer).
TVs and computers vs. when they didn't exist.
Intermittent wipers.
Automatic headlights.
I could go on.
But electronic fobs over mechanical keys? From a general engineering standpoint, adding complexity to any system with little to no upside is to be avoided (complexity reduces reliability).
In some ways it's less complex. There are fewer moving parts. It's true that the radio and electronics systems lack the inspectability of a mechanical key, but then neither do any of the electronic interlocks that they've had to add to modern mechanical keys.
But the main draw is the reduction in operational complexity. Constantly producing and replacing a key from my pocket to prove to the car that I should be allowed in, and allowed to start the engine - that's a drag, especially when it's raining or my hands are full. I like how the fob just gets out of my way.
What technology will bring us.
The millennials are taking over. Enjoy your Corvette while they're still legal.
