2006 C6 1-4 Shift
Old 07-03-2016, 07:05 PM
marblehead17
Navigator
marblehead17's Avatar
Default 2006 C6 1-4 Shift
I'm new to the Vette world. This 1-4 shift skip is annoying. To get rid of it, is it better to use the fuse method or the adapter at the transmission. What brand would you suggest?
Old 07-03-2016, 07:22 PM
D.Guerra
D.Guerra's Avatar
I'm not familiar with the fuse method. You could use the skip eliminator plug and go or have it tuned out during your dyno tune if you plan to mod her. Hope this helps.
marblehead17 (07-04-2016)
Old 07-03-2016, 07:26 PM
extrapilot
extrapilot's Avatar
You can use a "smart" fuse, short it out (blow the fuse) and install in the under hood fuse box and your done.
marblehead17 (07-03-2016)
Old 07-03-2016, 07:31 PM
SSTEVEGS
SSTEVEGS's Avatar
I used the smart fuse back in 08 when I bought my car. It's been flawless. It's a LOT easier than installing a shift skip eliminator...
Old 07-03-2016, 07:33 PM
marblehead17
Navigator
Default I've seen this advertised.
Any thoughts? http://complianceparts.com/c6cagstrblshoot.html
Originally Posted by extrapilot
You can use a "smart" fuse, short it out (blow the fuse) and install in the under hood fuse box and you done.
Old 07-03-2016, 07:34 PM
marblehead17
Navigator
Default What did you use?
I've seen this advertised. http://complianceparts.com/c6cagstrblshoot.html
Old 07-03-2016, 07:49 PM
extrapilot
extrapilot's Avatar
Doing the blown smart fuse is accomplishing the same thing as the cags skip fuse. I believe that they install a resistor in theirs.
The ECM or BCM, not sure which one, sees that there is a fuse installed, because both draw a small amount of current. If you pull the fuse out completely, a trouble code will come up.
I have had mine installed for three years with NO issues so far.
Old 07-03-2016, 09:23 PM
Another Don
Support Corvetteforum!
Another Don's Avatar
Just use your right foot on the go peddle. Leave it in first gear to 2500 rpm and you'll never have a problem with 1st to 4th
shift.
Old 07-04-2016, 12:44 PM
marblehead17
Navigator
Thanks. I'll try that.
Old 07-04-2016, 01:26 PM
dr_gallup
dr_gallup's Avatar
Originally Posted by marblehead17
I used one of those, worked perfectly. Much easier than having to get under the car to put in the inline resistor.
Old 07-04-2016, 03:31 PM
LMB-Z
LMB-Z's Avatar
I put the inline resistor under the car in. Took all of 3 minutes.
Old 07-04-2016, 03:54 PM
davo2110
davo2110's Avatar
Default go with the fuse method
Just a vote for the simple 'fuse' method--don't have to get under the car, and resistor is so simple to modify and install--save a buck, you can always go the other way if you aren't pleased.
Old 07-04-2016, 03:59 PM
Kent1999
Kent1999's Avatar
Received 1,651 Likes on 825 Posts
The Skip Shift transmission plug-in is cheap and easy -- $20 and 15 mins of your time (including the time spent putting the car up on ramps) and its all done.
The fuse method is cheaper, but may or may not work for you (didn't work on my 2012), and still leaves the skip shift solenoid wired in.
I've used the Skip Shift eliminator transmission plug-in for 10+ years on three different Corvettes --- NEVER a problem. The skip shift solenoid is 100% disconnected.
Old 07-04-2016, 04:16 PM
davo2110
davo2110's Avatar
there you have it.....honest difference of opinion, and 2 solutions, Just like America, and it is the 4th
Old 07-04-2016, 05:08 PM
Dano523
Dano523's Avatar
Received 3,041 Likes on 2,189 Posts
http://xse.com/leres/z06/cags.html
To 2006 C6 1-4 Shift
Quick Reply: 2006 C6 1-4 Shift
