Inexpensive mod that will put a smile in your face
#121
Got my order in from fabric gurus today. I ordered red, and my car is Crystal Red Metallic. It's a pretty good match in color so will work ... obviously doesn't have the sparkle of CRM but I don't think you'd want something like that.
I haven't installed it yet because I want to take my time doing it, but I cut off a small, maybe 3 inch, piece and stuck it in the seam. It goes in fairly easily and will not fall out ... adhesive is not needed. What appears to be "barbs" in the picture are just slits, presumably so you can turn corners easier. I haven't decided if I'll try to make the 90 degree turn on the door opening (the part that goes into the door jamb when the door is closed) or just cut it off flush. Making the turn would require a little surgery on the bead itself. The bead has red plastic around a white round stiff piece of plastic.
It looks like pretty good quality for the price. I'll decide whether I like it once I get it installed. If not, it's just a $12 mistake (counting shipping).
#122
Received 1,597 Likes
I got some from the OP's link, they have a local store so I was able to match the color exactly. I used a plastic trim tool to push it into the gap, which worked great. Best $4.26 I have ever spent.
#123
NSF
#124
Put mine in tonight. I used the 1/8" from fabricguru and it was almost too wide for my car. No way is it going to go in front of the passenger grab handle. I think I like it but am still undecided. I will leave it for awhile and see what I think.
#127
How much of it did you buy for enough to do both doors?
#128
Grimlock13 (04-08-2016)
#130
I think the darker gray will not be seen really with the black door panels.
RadarP3C (04-08-2016)
#132
Looks Great. I had the same issue with the passenger side, but what seemed to work was placing my knee on the door to keep it in place and with one hand lift up the door grab handle while at the same time pushing in the piping
Husker C6 (04-08-2016)
#134
Thanks, I think I will get someone to help and see if I can get it in there.
#136
#138
Got mine from faricguru today, but as Husker said its pretty thick. I just don't think it fits for me so its a no go Oh well I'll give it a pass
NSF
NSF
#140
I haven't put mine in yet ... been too cold in the eastern part of the country to fool with. I'll try it, and it it's too big (i.e., gaudy) I'll just remove it and throw it in the recycle bin.
