Caliper Color
Old 03-16-2016, 02:08 PM
grboggs
grboggs's Avatar
Originally Posted by C U IN REARVEIW
I vote yellow
*I second that!
Old 03-16-2016, 05:17 PM
Mad*Max
Mad*Max's Avatar
Received 1,507 Likes on 820 Posts
Red
Old 03-17-2016, 12:02 AM
chillwill
chillwill's Avatar
Paint them yellow
Old 03-17-2016, 11:32 AM
C U IN REARVEIW
C U IN REARVEIW's Avatar
[QUOTE=harley7453;1591787163]Hello guys. anyone have any pictures of a white corvette ,look to find a color to do my Calipers......2008 white
convertible.Thanks[/QUOT
Blue looks really good on a white car....imho
Old 03-17-2016, 11:59 AM
Doc750
Doc750's Avatar
gold .. be different
Old 03-19-2016, 09:49 PM
BBBx3
BBBx3's Avatar
Had mine done in red. Love it!!
harley7453 (03-26-2016)
Old 03-26-2016, 09:15 AM
Tyler_RN_EMT
Tyler_RN_EMT's Avatar
My vote is definitely yellow on a yellow car... I agree with stated earlier yellow and red always made me feel like a BigMac
I have always had excellent results with paint. I've done 5-6 vehicle this way and had excellent long lasting results. Just like any paint work prep is key. Everything needs to be very clean before paint. Remove what you can and paint each piece separately if possible. I chose to leave my calipers attached so I didn't have to bleed lines but it would be better to remove them. You can see the brackets I made to hold them during paint. I used duplicolor engine enamel as this was the closest match I could find to VY. I've also had good luck with caliper high heat paint.
Powder coat would be better im sure but I did mine with paint for maybe $30 total invested instead of the $300 plus powdercoat runs.
PS... I love the front lip/extended spoiler/side skirt combo on your car! I love the side skirts on the wide body's but typically don't like them on the narrow body's however yours are an exception! Looks awesome!!
Tyler
Old 03-26-2016, 07:21 PM
harley7453
harley7453's Avatar
Default calipers
How did you clean up the letters (corvette) after you painted them ??
harley7453
harley7453's Avatar
Tyler
Old 03-26-2016, 08:43 PM
Tyler_RN_EMT
The letters are flat so after the paint dries really well you can take a new razor blade and very carefully slide it along each letter and remove the paint. You can then apply clear over the whole caliper or you can clear after paint then remove both paint and clear with the razor blade... This is what I did because I did not want to wait the 72 hours or whatever it was recommended between paint and clear... Just read the can and make sure you apply coats in the timeframe directed
Old 03-26-2016, 09:04 PM
harley7453
harley7453's Avatar
[QUOTE=Tyler_RN_EMT;1591862099]The letters are flat so after the paint dries really well you can take a new razor blade and very carefully slide it along each letter and remove the paint. You can then apply clear over the whole caliper or you can clear after paint then remove both paint and clear with the razor blade... This is what I did because I did not want to wait the 72 hours or whatever it was recommended between paint and clear... Just read the can and make sure you apply coats in the timeframe directed[/QUO
Thank you.....by the way you did a great job.
Old 03-26-2016, 09:13 PM
berk4422
berk4422's Avatar
I did red powder coat with the white car. I think your yellow car would look great with yellow or black. Whenever I see a yellow car with red accents, I get hungry... Then I go to McDonald's...
Old 03-26-2016, 11:02 PM
  #33
grboggs
grboggs's Avatar
Another vote for yellow!!
Old 03-27-2016, 04:12 PM
  #34
1978280Z
1978280Z's Avatar
I vote yellow
Did you powder coat your wheels? That is the exact color i want to do on mine.
Old 03-27-2016, 05:13 PM
  #35
Never-Enough
Never-Enough's Avatar
Yellow or black
Old 03-27-2016, 05:42 PM
  #36
flyint
Support Corvetteforum!
flyint's Avatar
Red
Quick Reply: Caliper Color
