Need part number for roof (halo) seal
I'm trying to buy a replacement seal that sticks to the rear edge of the halo. Mine was torn off by an incompetent vinyl wrap installer.
At the website http://www.gmpartsonline.net/2007-ch...-corvette.html, I see part number 19167780, which looks like the right one, but it seems too inexpensive (I thought this seal cost between $35 and $55).
Could someone tell if if this is the right part number? I was told that the replacement will come with adhesive pre-applied.
Race Car Tech
P/N 19167780 should be the correct weather stripping. It comes in bulk and is cut to the correct size by the dealer most likely. It does seem cheap for sure.
Nothing else shows up on the diagrams. The targa top seals are more expensive for the sides.
Here are all the part numbers for the 2007 C6 in PDF format
http://www.autoricambi-euroamerica.c...ofessional.pdf
Race Car Tech
Here is another part number that may be what you are after.
p/n 15881010 which is the weather seal from the driver door to the passenger door over the halo. for around $200.00
Race Car Tech
Looking at the PDF you linked to, I see another part that looks like the right one: 15250758 SEAL,R/CMPT L/WDO FRT AUX. Do you how that part differs from the " 19167780 SEAL,RF RR PNL(CUT FROM BULK ROLL OF 35 FT)"? Maybe the former is precurved, rather than the straight bulk material.
I think that part goes on the front of the halo. What I need is on the rear.
Race Car Tech
