No FOB Detected, Cannot start the Car
Old 02-14-2016, 02:29 PM
xcutter
CF Senior Member
Support Corvetteforum!
xcutter's Avatar
Default No FOB Detected, Cannot start the Car
My 2008 Z06 says "No FOB Detected" when trying to start the car. I changed the battery in the FOB and it still does not work. Cannot unlock or lock doors either. Tried the second FOB and got the same results. I also tried starting the car with both FOB's in the glove box slot. It still says no FOB detected and will not start. Luckily this happened at home ind in the garage. Anybody have an idea of what the problem could be? I am glad I sprung for the GMEPP.
Old 02-14-2016, 02:38 PM
Not So Fast
Not So Fast's Avatar
Happen to have any kind of electronic devices plugged into the accessory outlet ???
NSF
Old 02-14-2016, 02:46 PM
bartsky
bartsky's Avatar
Make sure you put battery in fob correct side up.
xcutter
CF Senior Member
xcutter's Avatar
NSF
Just the hot wired radar detector which has been there for years.
Old 02-14-2016, 03:28 PM
Andy_greyz06
Andy_greyz06's Avatar
It's only happened twice. Dead car battery and when it was extremely cold outside. The cold weather issue was solved by putting the FOB in the glove box.
Old 02-14-2016, 03:37 PM
xcutter
CF Senior Member
xcutter's Avatar
Car battery is fine and the temperature is in the 70's. FOB in glove box does not work.
Old 02-14-2016, 04:06 PM
walleyejack
walleyejack's Avatar
happens, and same ole GM bs. i have tried all the "recommended" fixes, lasts for a week or 2, then same crap again. i just live with the bs fob.
Old 02-14-2016, 04:07 PM
xcutter
CF Senior Member
xcutter's Avatar
My problem is I cannot start the car at all. Can't live with that
Old 02-14-2016, 04:10 PM
RicK T
RicK T's Avatar
Take a look at eboggs' checklist in here. It pretty much covers everything:
https://www.corvetteforum.com/forums...sn-t-work.html
Old 02-14-2016, 04:13 PM
walleyejack
not even with fob in glove box ? and in position correctly ?
Old 02-14-2016, 04:15 PM
walleyejack
i am not a pessimist, but good luck with this.
Old 02-14-2016, 04:16 PM
xcutter
CF Senior Member
xcutter's Avatar
Tried both of my FOBS and neither worked in the glove box. My car battery is 3 years old this month. It has spent a lot of time on a battery tender. The original battery lasted 5 years. I just hooked up the battery tender and will see if that helps.
Old 02-14-2016, 04:20 PM
walleyejack
if the car battery is scrap, which i doubt it is, will be the same results.
simplegto
simplegto's Avatar
St. Jude Donor '11-'12-'13-'14
How did you get the door open? I think I would disconnect the battery and let everything reboot and hope for the best.
Old 02-14-2016, 04:21 PM
walleyejack
he probably used the key
Old 02-14-2016, 04:24 PM
xcutter
CF Senior Member
xcutter's Avatar
That is what I did
Old 02-14-2016, 04:28 PM
xcutter
CF Senior Member
xcutter's Avatar
It is probably not the car battery. The interior lights come on. I can open the door normally as the car is unlocked. The headlights also work.
To No FOB Detected, Cannot start the Car
Old 02-14-2016, 04:30 PM
walleyejack
yup, same as mine.. the Gm .29ct fob
Old 02-14-2016, 04:46 PM
unclecookie
unclecookie's Avatar
I did not have exactly the same problem as you, but my car would allow me to open the door, the interior lights worked, and the headlights worked. However, when I tried to start the car, suddenly all the lights went dim, and of course the car wouldn't start. I checked the battery with a volt meter and discovered it had only 11 volts in it. I hooked up a battery charger to it for a couple hours, and checked the voltage again, and it registered nearly 14 volts. When I tried to start the car again, the same thing happened. I checked the voltage at the battery and it was down to 10 volts. New battery cured my problem. The old battery had a dead cell apparently. I have no idea how old the battery was as it came in the car when I bought it last March. So even though your battery is only 3 years old, it still could be bad. JMHO
Old 02-14-2016, 04:50 PM
xcutter
CF Senior Member
xcutter's Avatar
When my battery died last time, I did not get the No FOB message. Why would the electronic door open, headlights and interior lights all work? Should be enough power to detect a FOB
Quick Reply: No FOB Detected, Cannot start the Car
