Installing Android Double Din
Hi guys, I plan on installing an Android Double Din Unit in my 2006 Corvette Z06. Installing a backup camera too. Can someone confirm what I have listed below is all I need to install the unit?
I understand that I may get bashed for wanting to install an Android Double Din but I have one installed in my 2006 G35 made by Parrot and I love it.
This is what I plan on ordering. Appreciate the help everyone.
Pumpkin Quad Core 7 inch 2 DIN Universal Android 4.4 Car Stereo Radio
Metra Electronics - Metra 95-3304
Metra 40-GM10 GM Antenna Adapter
Joycon EXR Steering Wheel Control
PAC OS2X Radio Replacement Interface with Onstar Retention for Select GM Class II Vehicles
Amazon.com : Pumpkin Quad Core 7 inch 2 DIN Universal Android 4.4 Car Stereo Radio HD 1024*600 Muti-touch Screen GPS Navigation Without DVD Player Support WIFI/3G/Bluetooth/OBD2/DVR/Mirror Link with Backup Camera : GPS & Navigation
Amazon.com: Metra Electronics - Metra 95-3304 Vehicle Mount For Radio - Abs Plastic - Matte Black "Product Category: Kits/Mounting Kits": Electronics
Amazon.com: Joycon EXR Steering Wheel Control PC Interface with Accessories and USB Cable: Computers & Accessories
Subbed.
I think that is all you need but I am looking to do something similer or the same unit.
Only thing I don't like about that unit itself is you have to put music on the internal 13GB memory and not the USB or SD slots. (a review states on USB it just starts autoplay from the begining on USB?)
SD must be dedicaded to the Nav by the description.
I do want something like that unit, I don't have unlimited data, so streaming music from pandora or the like is not an option for me.
Subbed.
I have an Android Double Din by Parrot on my G35 and the SD card slot is dedicated to the Nav as well. Luckily for me, I still have unlimited Data from Verizon Wireless so I use my hotspot for Spotify, Pandora, and Waze.
Are there Android Units out there that uses the USB differently?
The Metra mounting kit and Antenna look correct. I'm not sure about the harness. I dont have onstar, but I do have Blose, so used a different one. I got mine from Double D Mods, and he is not showing that harness as one he sells for the vette. His kit is most guaranteed to be the right one.
There are many android units out there. If you want to spend time researching them, head over to XDA-Developers android auto forums.
As for playing music from the USB, it depends on the music player app you have (if its a true Android system). Some apps rescan the whole USB library when it restarts, some players do not. GoneMAD player is reported to not rescan every time, but I haven't tried it yet.
Skanlez (11-18-2015)
Only other item I question in that list is the SWC board you picked, that seems like one that people use when they Adapt a tablet to be used as a "carputer" instead of a radio Head unit.
Though it may work just fine for the aplication.
As for your question on the USB, not sure on that either. Still doing research on which unit I want. I have all winter to pick one. I just noticed that in the reviews on that one, which i don't really like that, but if they all do it then I guess either live with it or get a "real" dedicated car stereo unit.
Received 4,508 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
also - Dennis used to carry the Parrot model (well he could get it) and he usually bundles everything including prewiring the harness. The bundle isn't free, but he knows these cars better than anybody. When I upgraded to a Kenwood this past spring, he set me up and the price was at least as good as Amazon, and the prewired harness made it REALLY easy.
The only thing I can not find is the output per speaker channel at the iso cable, so may end up having to run amps for output sound to the speakers instead.
Other than that, would make sure that the unit comes rooted or at least able to be rooted,
And would have a Satellite dvb-s2 Receiver installed now if you are having someone else install the radio. You can always just one of the usb ports to add in a dvb-t+dab receiver later.
As for the two usb ports on the back of the radio if you are not tying one up with either a sat receiver or 4g modem, have one extended to the center console grove box areas, and have the other one installed at at the cigar lighter plug area under the ash tray cover. Hence there is the mini usb jack on the face plate next to the sd card port, but with standard usb ports in other areas, you don't have USB wires hanging off the face for the deck instead.
Also, might want to see if there is a driver so you can run a usb elm-327, since if you have to run a blue tooth elm327 for say "Torque" app, then you end up with a lot more lag out of the blue tooth elm instead.
Hi mate i just installed a doube din android into mine the other day, im from the UK and made a post on the UK corvette forum if you wanted to look but ill post a summary of it
This is the link for the headunit http://www.ebay.co.uk/itm/1818609750...%3AMEBIDX%3AIT
This is the link for the harness http://www.ebay.co.uk/itm/3907170018...%3AMEBIDX%3AIT
The harness kit is pretty good as it comes with the chime module that you will need once the stock unit has been taken out
Also youll need one of these
As the harness does not come with an iso connection and it just makes installation that much easier and neater
Really happy with the headunit though looks 10x better than stock and works 10x better aswel. I fitted a backup camera and a DVR camera though this unit and it has a OBD app so you can monitor the car on your headunit using an obd adapter
The Bose part of the math is fine, since the Bose part is just an amp down line with speakers, and just connected to the radio via the ISO speaker wires out of the deck.
The OEM XM module in the car will not work with any aftermarket radio, Hence the OEM XM module only works with the factory radio since it's back and forth communication between the module and the radio is sent via the GM Lan Bus.
I am in the market for a new headunit that has at least a 7+ band EQ and can digitally time your speakers. I was looking at the NEX 4100 from Pioneer. It is a good unit, but if I can have the same for less I might do that. Right now I have a Kennwood DDX719. Pretty old. Also my car is a 2006 so I don't need onstar or steering wheel controls. On top of that do these Android units come with an HD antenna?
Also most android unit have sd and usb connections so just put a load of mp3's and your good to go
Unless you want to do some tricky wiring redo, you need the expensive harness. From what I remember, the factory plug does not have a standard 12v ignition power (red); only a 12v constant power (yellow). I think the ignition wire that GM uses, to tell the head unit when to turn on and off, is too low voltage for most after-market units.
Also, the Blose system sends low voltage signals from the head unit, to the Blose amp, then the amp powers the 7 speakers. So sending powered outputs that an after market head unit has to the Blose amp, can cause distortion/bad audio quality.
Will get everything installed after Thanksgiving. Will post after
