C6 Convertible Passenger Window
Hey guys/gals,
My passenger side window goes up and down about 1/4" repeatedly when I start the car. It stops once I hit the lock button or put the transmission in drive.
I called the dealer and they had me try a "window reset" where you run the window down, holding the button for an extra 10 seconds and then run the window up, again holding the button for an extra 10 seconds.....but it didn't work. He wasn't sure if you hold the button for 5 or 10 seconds so I tried both.
Does anyone know how to correctly perform the "window reset" on a 2009 C6 Convertible? or maybe there's a different problem?
Thanks!
Thanks!
You can/may also have to just replace it. They are a pretty cheap part.
http://stores.revolutionparts.com/cu...oe-gm/22751230
