Drivers door switch
Drivers door switch
Folks,
Drivers door started not opening sometimes. The window will index down but the door won't release. Took the switch off ,looked clean but alcoholed it off anyway, same deal. With the door open when the switch is pushed you can hear a click in the dash but sometimes the latch will release and sometimes not. It's too hot in the garage right now to try switching the switches. But it seems the problem is in the release mechanism rather than the switch. Like I said the window will index down but the latch won't release. It works intermittently. Any ideas?
Thanks, Dave
Thanks, Dave
Received 2,899 Likes
Might try to grease the latch and work it a few times. If not time to replace it.
https://www.corvetteforum.com/forums...sometimes.html
Folks,
So I played with the door open and closing the latch and pushing the pad and it appears the latch is bad. Sometimes it work sometimes not. I saw a video on YouTube and it doesn't look too complicated. Anybody done this repair? Can you easily remove the 2 manual door releases and reinsert them in the new latch? I've seen latches for sale with and without the manual releases. It would seem you could buy the latch without the manual releases and use the ones in the car if they can be removed from the bad latch and rebooked to the new latch. Anyone done this?
Thanks, Dave
Thanks, Dave
Just had the same exact issue....i tried lube, no help..... Dealer replaced the lock mechanism in the door jamb....I now find myself using the floor release naturally....
Folks,
Thanks, Dave
Thanks, Dave
