160 Thermostat
160 Thermostat
I received a 160 from Chuck Cow and i'm going to be changing it this weekend.
I can't for the life of me find any threads on where the thermostat is "From a picture perspective," I know its 2 bolts in a housing that connects to a hose on the passenger side but I can't for the life of me find out WHERE it is.
Does any one have any pictures of their installation of the thermostat?
Tranny issues due to heat in the c6's? NO THANKS.
I'd rather have it be nice and cool.
Please correct if wrong here
A 160' thermo just opens earlier that a 180' thermo doesn't it?
It doesn't improve the cooling ability of the system at all does it??
So if you live where its cold then what are the advantages, alternately if you live where its hot ???
Just a question
NSF
Just a question
NSF
Received 1,136 Likes
Just a question
NSF
Just a question
NSF
Then, for emissions reasons, they started upping them to 200, 210 in the '70s I think.
Who knows what the ideal temp is for any given engine, but I would bet that GM knows the best temps for our Vettes. And I'm sure it's all balanced out with the fuel, spark advance, etc.
It should keep the coolant that much cooler than a hotter thermo will, assuming the cooling system is capable. When I was young most cars had 180s in them as I recall. But if the engine runs too cool then it isn't running efficient.
I think we're going to get into a lot of different opinions on this so I'll just add my 10 cents worth. First off I have a GS (all stock) and it runs right at 190 degrees the way it is. It has a dry sump oil system that keeps the oil temp down. If you put a 160 stat in, and your cooling system is good enough, it will keep your water temp at (around) 160 degrees. Some systems may not be able to do this because they not large enough (number of rows of radiator cores, fan ability, and amount of coolent). Remove the stat all together and run the car and you'll see just how good your cooling system is. Your water temp may not reach 150 degrees!
I just cannot believe the ignorance/arrogance that I read here. changing the thermostat ALONG with a TUNE is the point, for RACING. If you really think sitting in traffic with a 160 is keeping your car cooler than a 180 in the stock configuration then you have a lot to learn.
The opening (fully Opened) on a 160 & 180 is the SAME SIZE.
At operating temp. the same amount of water flows thru both.
The settings in your computer that control the ON/OFF points of your fans is what will change (slightly) the operating temp. of you car. It's basic physics, not rocket science.
Good Luck with your discussion.
Of course I could be wrong
And remove it so it will nor even get to 150',uh I don't think so again, sorry
NSF
I no longer have my beloved '05 Coupe that Chuck COW did his tune for me (several years ago). Yes, there was a 160* thermostat installed with the tune, and the car ran "hotter", especially on the highway. I have a few friends that also have 160* thermostats, and they also run hotter than with the stock thermostat. All cars with the 160*'s are tuned, or rebuilt with much more HP than stock. On my car, as previously mentioned by someone else, the fan settings were changed so they came on sooner, in fact, they were "on" almost all the time when the car was running. Long story short, all worked well, never an overheat.
