Oil change drain bolt stuck!
#102
Bread bag concerns aside, using the right hand method, wouldn't you point your thumb down which means you turn clockwise while looking at bolt from below??? now you got me confused and I got to go to the shop to see which way to turn the plug on my car
#103
Now that's just plain wrong. You tuck the twirled bag and tuck it under the loaf of bread. That way the bread stays right side of on the counter.
#104
If you're home, just look up at your ceiling fan light fixture. Imagine you're changing the light bulb. Reach up and which way would you turn the light bulb to remove?
Ok, and now for the light bulb jokes ....
#108
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
I am thinking ... anyone that can't figure out which direction to properly loosen or tighten a simple engine oil drain bolt probably should not be changing there own engine oil.
#109
Received 2,897 Likes
#110
I found the Fumoto valves (which I have used on other cars) really didn't work on my 2013 LS7 due to the way the pan was cast.....I could have used extensions but didn't want to.
I used these instead (https://www.nospillsystems.com/index.cfm), a little pricier than Fumoto but work great and don't hang down/out from the oil pan:
#112
#113
has anyone heard from the OP yet? i hope to hell he is still with us. (the living) i sometimes wonder why someone would post a question and then all of a sudden disappear. i guess some people just don't appreciate the advice they seek here on the forum. all i can say is
#114
#115
Ah, the light has come on! Right hand method curls fingers clockwise for bolt removal but that is in fact the same as turning the bolt counter clockwise with the wrench.
#116
Think about a clock!
Think about a clock, looking at the HEAD of the bolt, turn the the bolt and wrench Counter-clockwise to loosen. To tighten, turn the wrench and bolt clockwise as the hands of a clock move. Almost seventy years of experience, NO problems. Of course, for LEFT hand bolts or threads, just do the opposite.
#117
How do you know if its a LH or RH thread?
#118
Good point. I learned the hard way years ago when changing differential gears that the ring bolts were LH and not the common RH. I had a 600' lb+ impact gun and snapped the heads off two bolts when trying to remove them before discovering they were LH. DOH!?
#119
I have found that through experience that if a bolt gets tighter as you try to loosen it, you are probably going the wrong way, and before you continue, change direction. Works most of the time for me. But then I am simple minded.
#120
Bolts with left hand threads sometimes have LH or L on the head. Older cars I've worked on did not have a letter on the wheel studs, and I've also seen axle nuts with LH threads that were not marked. Interestingly, the LH axle nuts were on the right side of the vehicle.
