How many hours to change a harmonic balancer
Mike Green9 (06-06-2022)
a good shop....4 hours maybe less....
Harmonic Balancer
mine took 2.5 hours to complete. There is a trick if you have a lift, take off the 4 main bolts to the power steering rack, remove the rack from the steering shaft , take off the motor mounts and lift the engine with a floor jack while it's in the air, then removed both front wheels and disassemble the upper control arms, then you'll have room to manuwver the power steering unit so you can remove the balancer without having to pull out the rack. The hardest part was removing the balancer , it was a PITA however there was enough room to put in a small puller to pull out the old Balancer. Total cost was 553.00 at VIP and I watched them do the whole job from removal to reassembly in that time period. You do not need to remove the power steering unit all together. Labor was 407, plus they gave me a free alignment, and warrantied my rack for 3 years. Great deal. I literally watched them do the entire job. They made it look real easy.
The following 4 users liked this post by Crzytim:
gdmoore01 (06-04-2022),
Mike Green9 (06-06-2022),
Sandra Hyatt Sellers (10-10-2022),
sonik_fury (06-05-2022)
The following 2 users liked this post by Whodamans:
This 1LT red car took me about 6.5 hours.
This 3LT Z51 car took me about 7.5 hours. I have all the correct pullers and installers and air equipment and have been doing this a long time. Everything goes back where it's supposed to with no prybar damage. If somebody quotes you 2.5 hours to do this job, run away.
