Battery Tender (Help)
I am looking to buy a battery tender. Went to a car show last week and they had a Battery Saver - It had LED readout and would charge or maintain a battery.
Does anyone know anything about these? What brand does everyone recommend to keep the battery up when not driving
THANKS!!!
THANKS!!!
1 Post
THANKS!!!
THANKS!!!
Battery Tender Junior. This is a tender/maintainer, not a charger. You don't need a lot of power and, in fact, the lower power doesn't damage he battery as much as a higher power unit can.
Received 1,013 Likes
2016 Corvette of Year
2015 C6 of Year Finalist
I have the Ctek multi us 3300 on my Vette and Harley,
Charges and maintains as well.
EDIT: Get the magnetic connection that goes in the front grill, that way when you back out it just disconnects, and reconnecting is a cinch, just put the connector on the front, much easier than the cig adapter.
1 Post
Battery tender junior can be left hooked up all the time when not driving the car but I don't do that because some say it should be disconnected every 60 days. I just hook mine up once or twice a month until the light turns green then I disconnect it I have never had a dead battery with this method.
Most any brand battery charger /maintainer will do the job, i have a Sears unit and two Battery tender brands and they all work good. I use them on my two Harley's and one on my car. I installed the Mag Charger on my Vette and like it a lot, you should check it out. it works great and all you have to do is apply the magnetic charger to the outside of the car near the front of the grill, once the unit is installed. I think it will work with most brands of chargers but i would check.
Received 1,136 Likes
CTEK does not list it as an accessory, but I did find this one that is independently made.
Is that what you guys are using?
I have read about the magnetic connector before on CF, and it does seem the be the easiest way.
https://www.corvetteforum.com/forums...ry-tender.html
I don't know the difference between The Battery Tender Junior and Battery Tender Plus but instructions say it can be left connected indefinitely. Like windyC6 I don't like to keep it connected all of the time though.
I have three vehicles, that are not daily drivers, i leave the tenders on all of them 24/7 and have never had any issues, they should be safe they automatically stop charging when they reach their full charge states. But however you do it , it all works if i started unplugging any of them i would most likely sooner or later forget to plug them back in.
Lots of forum thoughts on this issue as well. This post seems pretty accurate when saying that most will do the job well. I got the Sears units also which I'm sure are made by someone else but regardless they do the job on my Vette and Harley. Not sure why some say that a maintainer isn't a charger, kinda seems to me that any device that maintains the battery has to be charging it.....interesting. Either way if your battery is low I think most maintainers will also charge it, but it may take a while. Another mis-conception is that one should keep it hooked up 24 - 7 for it to work properly. I personally don't like leaving any kind of electrical equipment plugged in for long periods. During the winter I just plug my tender in about 3-4 times a week for at least 3-4 hours and all works fine.
Yes that is the one, I got mine off a forum vendor here
The guy on the website says he can just drive away and it will fall off, interesting, not that I would do that.
The battery tender brand will stop charging when it hits the upper voltage level of about 14.2, then turn itself off to let the voltage fall to 13.2, then turn itself back on to maintain 13.2v. This is an ideal float voltage, the battery can sit for months or years at 13.2 without damage as long as you keep the battery topped off with distilled water. So inspect the water level once a week, adjust your inspection frequency as needed. Just don't let it dry out.
Josh W. (05-09-2016)
