How to maintain factory leather
So I've tried a few searches but want to get to the right info. I've got a new to me 2007 c6 z51 with the two tone leather option (black & red). The car has 14.7k miles on it and the leather is in fantastic shape right now. However, I have seen in older cars, the damage that can happen to these seats. What is the best way to make sure this doesn't happen. I've seen proponents of Z10 and Leatherique and 303 UV coating but want the most practical approach. Not trying to start fights here. Help a brother out.
I don't do much of anything to mine except keep it clean. I've used leather cream a couple of times but I don't think it's really necessary. I think you have to be careful if you do that on the perforated seats ...might clog the holes. Over time, the leather looks a bit "crinkly", but to me the old leather look just gives it some class.
Unless I'm mistaken, the only real leather parts of the seats are the sitting surfaces, i.e., the center of the bottom and the center of the back. The bolsters and headrests are simulated leather. And for good reason ... it wears a lot longer. I had real leather on a previous car on tbe bolsters and had to replace the one by the door twice because getting in and out wore a hole in it. That doesn't happen with the vinyl (or whatever it is).
A leather cleaner and treatment from Mothers, Meguires, Addams etc should do the trick. I also use a California Pop Top to block the sun in our Sunny Hot location.
Even the real leather parts are urethane coated. You're wasting your time with leather cleaners and conditioners. Just use 303 to keep sun from damaging and keep them clean with a mild water/pH balanced soap mixture.
looks like 303 is the best option for prevention. it looks like in a lot of cases the vinyl/leather is dried out. is there any way/point to "rehydrate" the seats.
I'm planning on getting some Wet Okole covers to protect my pretty red leather seats.
I had a set of those covers on my Jeep Wrangler and they are FANTASTIC. Fit is excellent, quality is high, and they don't fade easily. They add a little cushioning too. The only warning I issue is that if you live somewhere where it is really hot and you drive topless for a long time, you might get some swamp butt because the neoprene will make you sweat if you are stuck in it for a while in the heat!
Keeping the leather seats nice!
The best way to keep the drivers seat nice is to learn how to get in and out of the car w/o doing damage to the side bolsters. With the door open, back up to the opening, and set straight down with your legs planted on the driveway, so you are not sliding across the bolster. My car is nine years old and the seats look like new. I just use a damp cloth to wipe them off occasionally! You can use a protectant but with the leather/ vinyl that is used, has a film from the factory already on it!
Watch keeping your wallet in your back pocket while driving. I put a nice hole in my C5 seats from that after awhile. I did put 86k on my C5, but I usually don't sit on my wallet in my C6 now.
http://www.premiumboatcare.com/gold-...hannelid=FROOG
I've used that (it's in most auto stores) on all of my cars.
No cracks or any other problems. My BMW was 15 yrs old and the seats looked new.
Received 1,681 Likes
Main thing you can do to keep them looking new is not to drag your body over the bolsters getting in and out of the car. Place your rear in the middle of the seat then lift your feet in.
Agree with everything said here....but would add that I have used Zaino leather care product on all my leather equipped vehicles and it may not be necessary but it sure smells like the real deal and i think adds a more supple, softer feel to older leather. But you will read all kinds of opinions .....just do what you think makes the seats look good!
Lets not forget about the Wizard Of Oz shuffle and kick those feet together once or twice before swinging them in....LOL
SyberSaint (04-09-2016)
Received 3,658 Likes
2016 C6 of Year Finalist
I just clean mine with Meguiar's All-Purpose cleaner diluted 10:1 using distilled water, followed by a wipe down with Meguiar's X-Press spray wax. My seats look new as do my Tahoe seats which are 8 years old.
Check out Darren Priest and his videos on how to clean and maintain leather seats.
EMT311 (04-06-2016)
