Sticking shifter on C6
Has anyone come up with a solution for the shift lever in the C6 sticking in park other than the "zip tie" application? this is a real PIA
I was doing the same thing, but it start getting where I would have to do this several times sometimes before it would work! So, I just cut the tab before I was left stranded.
Race Car Tech
The real kicker is even if GM does replace your sticky shifter assembly, it does not guarantee that it will not happen again to the new shifter. Mine did it a few times. Tie back the locking pawl and be done with it. No more worries.
Last edited by 4SUMERZ; 02-23-2015 at 02:10 PM. Reason: Added PDF for locking the pawl back
Do that and it's literally impossible for the shifter to get stuck in park ever again.
C6 Stuck in Park Fix
The cause of the stuck in park conditions is the failure of the Micro Switch in series with the Park Release Solenoid. The factory Micro Switch is a Burgess V4NCSE, rated for 5A, 250V with a non-inductive source. The resistance of this switch increases over time because it is in series with the large inductance of the Solenoid. When the shifter is in park, the solenoid is supposed to be grounded through the switch. When +12V is applied to the other terminal of the Solenoid, it activates and retracts the pawl that locks the shifter in park. When you shift out of park, the micro switch opens and tries to interrupt the 0.5 A of current through the 25 Ohm solenoid. You can not instantaneously change the current in an inductor (solenoid). When the switch opens, the voltage of the inductor will increase to whatever is needed to allow the current to flow. This will cause arching across the contacts in the Micro Switch. Over time, the contacts become pitted and highly resistive. This is a GM design flaw. Standard procedure when interrupting the current in an inductor is to put a diode in parallel with the inductor. The diode is normally reversed biased. When the switch opens, the inductive current will flow through the diode, instead of flowing through the arcing of the switch. I used a 1N4937 diode across the solenoid. It is rated for 600V, 1A. The 1N4933, 4934, 4935, 4936 would work equally as well. I replaced the switch with the Omron SS-10GL2. It is rated for 10A, 250V. I did not have to make any modification to the switch.
I cut the paw off a year ago. A little bit of work but it was well worth it. I never worry if it will get stuck again. I figured i might as well cut it off instead of a zip tie as long as it was right in front of me.
