C6 Manual Hood Release will not open hood. What do I do to get the hood open.
Old 01-03-2015, 10:18 AM
larry mack
1st Gear
larry mack's Avatar
Default C6 Manual Hood Release will not open hood. What do I do to get the hood open.
C6 2006 model manual hood release will not open the hood. Plenty of advice on how to open a C4 corvette with the same issue but nothing on how to bypass the C6 manual hood release problem. Help....any advice would be appreciated. Larry in Pharr Texas.
larry mack is offline
Old 01-04-2015, 12:02 AM
child_of_fire
child_of_fire's Avatar
does it feel like the latch is still being controlled by the cable? is the release "loose" and feel unconnected?
child_of_fire is offline
Old 01-04-2015, 10:05 AM
etaylor14
etaylor14's Avatar
I read a post a long time ago that said you can release the latches by lowering the rear of the wheel wells and releasing the latches with a long screwdriver. Maybe someone can find the post for you. Good Luck!
etaylor14 is offline
Old 01-04-2015, 10:54 AM
EVRose
EVRose's Avatar
First time I've ever heard of this happening.
EVRose is offline
Old 03-18-2021, 08:40 PM
c10gabino
1st Gear
c10gabino's Avatar
Werebu able to fine an easy way to open the hood latch brotha I’m here from mcallen tx
c10gabino is offline
Old 03-18-2021, 10:03 PM
87SAM
87SAM's Avatar
There may not be an easy way. Best case would be that the cables are still intact but just have slack in them. From what I have read, you may
be able to use vise gripes or something and pull the on cables where the manual release lever is. If cable is broken, you may have to take the wheel liners out and try to get to the latches and release each one manually.
87SAM is offline
Old 03-18-2021, 10:15 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
OP hasn't been on the forum in 6 years.
Last Activity: 01-03-2015 09:44 AM
Vette_DD is offline
To C6 Manual Hood Release will not open hood. What do I do to get the hood open.
Quick Reply: C6 Manual Hood Release will not open hood. What do I do to get the hood open.
