Any way to make the foglights default to being on?
I have an 07 z51, and hate having to turn the foglight control everytime I turn the car on. Is there any way to make it default to on rather than off?
Race Car Tech
No, not unless you rewire them from the fog light fuse #22 (engine fuse block), to an on/off switch or to a fuse that only gets power when the car starts (seat heaters). The Fog light fuse is live all the time, but the relay only gets power to the fog light side, once the car is started.
That can be easily accomplished if you really want to do it.
Good Luck
Good Luck
Thanks!!!
Race Car Tech
I started a similar thread last week asking the same question. So - is it just a jumper we need to go from the DRL fuse to #22? Any other insights would be appreciated. I'd like to have DRL and foglights on by default - assuming this is what the OP was looking for as well.
Thanks!!!
Thanks!!!
I have the wiring diagram, and jumpering the relay from the fuse could do some damage to the headlight/circuit
It's probably best to just run new wires from a switch to the fog lights.
If you want the wiring diagrams for all the electrical in the C6, PM me your e-mail address. It's too big a file to post on here. The headlight Fog light electrical diagram is on page 74 0f 159.
Maybe with the wiring diagram, some electrical engineer can get it jumpered??????
Thanks!!!
Thanks!!!
When My headlights went out my short term was a jumper to the parking lights.
It is easy enough and simple to revert back to normal.
You will be the only one who sees it.
The wiring circuit for the fogs go through the Body Control Module (BCM) so it's complicated to just get the fog lights on all the time. The headlight circuit will shut off the fog lights when the hi beams go on. It's all tied in together.
I suppose you could cut the line to the body control module and then connect a wire from the headlamp relay output to the fog lamp relay, so that anytime the headlights were on, the fog lights also came on.
I havent given a Z51 ticket in so long that I may loose my badge...so...You Dont Have A Z51! You have a coupe or vert with a suspension/brake upgrade the factory specifies as Z51. Its not a model like Z06/ZR1/GS. Ok, met my quota for the month.
Race Car Tech
Thanks!!!
Thanks!!!
Hope it helps
Back to the subject at hand, a relay is a relay. There shouldn't be any problem jumping across the open contacts. They are isolated from the BCM and the can-bus.
I like it. Another of my favorites are those who call an air filter a CAI. We need a ticket for that, especially in the for sale threads.
Thanks for the good replies. I'll have to see about doing it. No thanks to the snob who talked about the z51 not being a "model". Make sure you don't say your car is silver. It's PAINTED silver. You have a coupe / vert that the factory specified to paint silver. It's not a model.
As to the question, on my pickup, I was able to jump a couple of fuses in the fuse box in order to have the hi and low beams stay on at the same time. Not sure if that will help lead you in the right direction or not. I find myself using the fogs more and more at night recently. The crazed headlights just don't give as much light right in front of you.
What I hate even more than that is people that decide they need bright blue (>6000k bulbs), purple, red, green, pink or any other stupid HID color in their fogs - which they then proceed to use when they don't need them. Yellow is the best color for fog lights that you actually use. They cut through road mist, fog, rain, and snow. That's why on my truck, I have yellow HID's that I only use during inclement weather, and they're awesome. If I ever upgrade any lights on mine, I'll be going yellow HIDs.
You gotta love this. There's always different views and opinions. Sometimes our skin is thick sometimes not so thick. Many of us poke fun on posts with no ill intent. There are a few that are not doing it in jest. I have a Z51! I say this especially with the current ads that are going around with the new Vettes. They said "We have they latest Corvette Z51 at our dealership". Now we realize the dealerships are all knowing so how can I argue with that. As for driving around with the fog lights on, I say the more visiable you are the better. Especially with the high % of bad drivers out there.
I posted THIS THREAD to show how to safely have the fogs comme on with the brights. You could do the same, only modify the source to use a switched +12v pin instead of the high beam source I used.
I've actually been considering installing LED bulbs into the fog housings and doing this mod myself
Not sure about where you guys live....but in some states its illegal to have your fog lights on if it isn't foggy....imagine that. Might not be a bad law as it would help keep the people from having them on for no reason.
Windy - good point, certainly no one is looking for fighting johnny law - quite the opposite - just like more opportunity to be seen.
BTW - on a few quick searches there are a few states that have issue with fog lights being on in non foggy situations, but the most common requirement that I saw was to not have more than 4 forward facing lights on at one time.
