Battery Tender
Battery Tender
Hello
How big of a battery tender should I use when I store my 07/Z06 for the winter and do I leave it plugged in all the time or do I unplug it after the battery is charged.
Thanks guys.
Thanks guys.
I leave my battery in the car during winter storage. I keep my maintainer plugged in from November until April. I use this one from wallyworld...
http://www.walmart.com/ip/Schumacher...5-Amp/15140193
Smallest you can find. The slower the charge rate the less damage is done by the charge. You get a big charger if you are in a hurry and don't mind how much damage you do to the battery. You get a small charger if you have time to treat the battery well. A tender can be far smaller since you don't care if it takes 2 days to get to a full charge and holding the charge requires less than 10mA.
A tender/maintainer is designed to be plugged in and left on. That's why it is a tender/maintainer and not a charger. I've left a Battery Tender Jr. on a battery in a garage for 4 years continously and over 8 years most of the time. Still good as new.
Received 1,136 Likes
Also: A trickle (1 amp or less) gives the battery a full "deep" charge; the fast chargers only give it a surface charge which is probably enough to start your car, depending on the condition of the battery, but it will still need to be fully charged by driving or trickle charging.
Received 3,652 Likes
2016 C6 of Year Finalist
Schumacher XM1-5 Maintainer, 1.5-Amp $15.98.
I use a Battery Tender Jr. I have 3 of them (1 for the vette and 2 for our Harleys) I have been using them for several year and have yet to have any problem. I usually put my vette away for the winter from December to late March, and keep the BT Jr hooked up the entire time. They are ~$30 each.
The one that I have is a Motomaster brand (made specifically for Canadian Tire stores up here) and it's listed as a battery charger/maintainer. On the back it lists the input as being 120V AC, 60hz, 0.5A and the output is listed as 12V DC, 2A. So does this mean it's a 2 amp charger or a 0.5 amp charger? I have been leaving it attached for the entire winter storage period, and haven't had any problems, but if it is a 2 amp charger does this mean it's a bit too powerful to leave attached the entire time? Should I be periodically removing it and letting the battery sit so as to not overcharge it? I think when I bought it the manual did say that it shuts off the charging when it senses it's up to full charge, but I am still concerned nonetheless.
Race Car Tech
Attachment 47839136
Here's my choice. A little more expensive than some of the above but it comes a 10 year warranty.
Race Car Tech
I have a 1.5 amp and I use that or my 1 amp on the bike or boat battery. Not a big deal, I wouldn't worry about it, but like FtMorganAl said above the smallest (output amps) is better for the battery.
The GM one that came with my C6 uses the cigarette lighter connection. It works fine, but I don't like that it uses the cig lighter connection. My process is to lower the window a crack so the wire doesn't pinch the molding. I would have preferred to have alligator clamps so I can attach to the battery. Easier to leave the hood unlatched. My "to do" list includes replacing the cig lighter connector with alligators, but hasn't been my priority.
So, I recommend an inexpensive one that includes alligator clips to attach to the battery.
I use a CTEK 3300 and plug it in the cigarette lighter jack in the center console. I run the wire out the bottom of the door in the little notch so the wire does not pinch. Has worked fine for three years.
One thing is for sure, you don't need to spend big $$$ on a battery tender. I bought mine at Lowes for about $20; it has both the batter clips and the cigarette lighter adapters that plug and play. The unit monitors itself, so it shuts down when the battery is at capacity- - -I used it all last Winter and it performed flawlessly.
