winterizing the fuel
Hi folks. Got a 2012 Grand Sport, and I am getting ready to put it away for the winter. (MOntana). Does anyone have an opinion on a good fuel preservative. I don't care what it costs. I had to replace a fuel pump on this new car, and I do not want to do it again. I have heard that SEAFOAM is very good. Any ideas? Any suggestions are greatly appreciated. t.
Fill your tank and add a bottle of Stabil or Seafoam at the station. Then drive it for about 15 minutes before you put her away to get the Stabil / Seafoam through the system. Both are good. Don't start your car again till you're ready to drive her for the next season or you'll end up with moisture in your lines which can cause problems.
I use Stabil in all engines that might sit for a while. The most important thing with a C6 is to keep a full tank of gas. The level sensor in the right tank can corrode if it is dry because you have less than half a tank on the gauge. The fuel pump is in the left tank and always under fuel so that should never be an issue with these cars. Ethanol will absorb some water so stay away from that if possible.
Add Sta-bil fill tank. Drive a couple miles to get into fuel lines. Park car and clean it inside and out,add 5lbs. Air to tires, connect battery tender and cover it. See you in the spring.
Why not fully charge and remove the battery?
Received 2,486 Likes
St. Jude Donor '15
"In honor of jpee"
Here's a layman's explanation:
"To keep sulfation from occurring, a battery need only be maintained in a fully charged state. For those vehicles and crafts used on a daily or semi-daily basis, this isn’t a problem. However, pleasure boats, personal aircraft, recreational vehicles, off-road vehicles, and motorcycles that are used occasionally will develop battery sulfation, barring preventative measures.
To slow this process, some people disconnect the battery from the vehicle when not in use, but sulfation and self-discharge still occur. A better, more convenient and effective solution is to use a device called a battery conditioner. A battery conditioner will keep the battery fully charged between uses, without overcharging it. Battery Minder and Battery Tender are examples of two such products, designed specifically to prevent sulfation and extend battery life by as much as several years."
fr. here: http://www.wisegeek.com/how-does-sul...-a-battery.htm
Received 1,136 Likes
Also, some newer maintainers keep the battery from sulfating which eventually kills a battery. A slowly discharging batt. will sulfate.
My Harley sat for two years in an unheated area, with a battery tender, and the battery was fine when I finally started it up.
@duanepillar: I've read that before about the dryer sheets, but DOES IT REALLY WORK? This is going to be a big concern of mine, living in the woods despite having two killer cats.
St. Jude Donor '15
"In honor of jpee"
I don't know about the dryer sheets (the smellier the better, as it was first written ). I will say that I used to have a "drafty" garage door. So, I took four of those "aromatic" sheets, stuffed them in my tailpipes on a string to pull them out, and put a big note on the car cover "Remove Dryer Sheets."
I think I will put steel wool in the exhaust.
Received 3,658 Likes
2016 C6 of Year Finalist
I gotta say two things: I would think the soot would keep them out; what are they gonna do up there anyway?
Also, won't the dryer sheets loose their scent well before spring?
Just askin...
Stabilizer is simply a waste of money. Can any of you post independent data showing it does anything? A long time ago I did try Stabil in one of my ATV's and in the spring noticed a red, powdery residue in the bottom of the gas tank. Never again.
Mice in the exhaust? What are they going to do, crawl up the pipes and eat the catalytic converters?
You can always put tennis ***** in your exhaust pipes to keep critters out. I don't, but I do make sure the cover is down tight over the pipes. I had mice get into the motor of my Monte Carlo a couple years back and put the Bounce sheets in the following year. Worked great. Now I do it every year with the Vette. 3 in the motor, one or two inside, and a few under the car that I replace once a month.
My buddy owns a storage garage for his own cars and he's been doing that for YEARS (believe me.......he has mice) and he's the one who told me about the dryer sheets. He only uses Bounce and said since he started using them he's had no issues with the critters in the motor or anywhere the sheets are.
As for the Stabil, it's what I use with no issues, but you can use Seafoam or another stabilizer. Unfortunately, I don't live where they sell non ethanol gas. It all has ethanol here.
