Finally happened to me
Tuesday morning I went out and started my 2011GS to go to work and immediately noticed a rough idle. Then engine light came on and 'service traction control system' message appeared. I am saying 'WTF'. I am a bout three minutes from my local Chevy dealership. The owner is a friend and my step son is a service writer. He sees me pull in and comes out to talk. After relaying the issue he pops the hood and immediately spots a plug wire off on the passenger side. He points out the corrosion on the wire in the boot and explains that they now use plastic plug clips instead of metal and they get brittle and break. He recommends replacing the plug wires at a deal price of $85 and he will put them on no charge. Also informed that the new wires will have a lifetime warranty. So....I found factory wires on Ebay for $45+$6 and lots of after market choices. Should not have to replace plug wires at 21k miles but if I have to do it should I go factory or quality aftermarket like Accel, MDS or ZZP? Funny that I have read about plug wires coming loose on the forum and how you should check them but it never even occurred to me that was the problem. Anyway jus asking for plug wire opinions. The car is a stock DD.
If it was me... I'd snap the plug wire back on and call it a day. Wires should be good for much long than 21K miles as you'd mentioned.
Received 2,897 Likes
On the other hand, it is a three year old car in a hot humid climate.
I would have gone for the new wires for under $100, installed free, with lifetime warranty, done by friends and family, while-I'm-already-in-there, option.
