Defrost
Old 09-11-2014, 11:23 PM
whitesnake81
whitesnake81's Avatar
Default Defrost
2005 C6 - The A/C blows cold and through the vents as it should. I push
the defrost button and the air moves to the floor board and not
to the defrost vent on top of the dash. I push the defrost button again and it circulates back to the A/C vent. In the mornings while running the A/C, it will cause moisture on the outside of the windshield in front of the defrost vent. Does anyone know what would cause the defrost not to work?
I would appreciate any help on this.
Old 07-11-2015, 09:35 AM
GotChrist?
GotChrist?'s Avatar
Old thread. Mine just started doing this too. The air would also go warm/hot at times while the AC was on.
Old 07-12-2015, 03:58 AM
Knob Jockey
Support Corvetteforum!
Knob Jockey's Avatar
St. Jude Donor '11-'12-'13-'14-'15
There was a thread about the 'mode doors' that re-direct the airflow, that may address your problem. I'll post a link if I can find it.
Major PITA to repair. Good Luck
Old 07-15-2015, 08:59 PM
GotChrist?
GotChrist?'s Avatar
Thanks, KJ. I don't believe mine is due to a delaminated mode door because it doesn't make a weird sound. It acts like the vacuum hoses that control it are switched. However, does the C6 use vacuum hoses to actuate the mode door? I don't even know where to begin looking. I had the var in for a recall and hope the mechanic didn't mess things up.
John
Old 07-15-2015, 09:41 PM
ChevyDave
ChevyDave's Avatar
John
the parts blowup shows actuators..
just as a side note, i believe there are actuators that move parts (like shades) inside the unit, thats where usually the problem is when air moves incorrectly or fails to move properly.
this is a blow-up of the a/c unit. i think (but not positive) that the shades are item #1. the actuator is item #8, there are 2 of them(i know it show 3 of them but parts list says 2 required). also #29 is an actuator.
i am not a a/c unit repair person, but from what i can tell...
the purple area is for the dash vent air ,
the brown circle area is the shades
this is info i had saved from many years ago, i dont know what year the blow-up is for, but suspect its valid for all C6
Old 07-20-2015, 02:51 PM
GotChrist?
GotChrist?'s Avatar
Thank you. Great diagram. If an actuator stops working, how does that make air flow to a whole nether part of the car? Seems like air woudl continue to flow to the vents rather than moving to the floor if the defrost actuator broke.
Old 07-31-2015, 02:32 PM
GotChrist?
GotChrist?'s Avatar
Default SOLVED! Disconnected the battery. Defrost works fine.
Either in this thread or another, someone mentioned that disconnecting the battery has corrected this issue with some who have experienced. I did just that. Disconnected the negative cable from the battery for one minute then reconnected. Defrost now works perfect.
God bless!
To Defrost
Quick Reply: Defrost
