Camber angle
Camber angle
I got my 2010 GS inspected the other day, it passed.
But the service guy said I'm getting front tire wear
on the inside of the tire. He says it's because of the
built in negative camber. He said it is not adjustable.
I understand camber and the handling of the car
in corners and turns. And A-arms and transverse leaf springs.
My question is why can't it be adjusted, at least some.
Thanks, Kliph
Thanks, Kliph
To help you understand . . .
There are two ways to adjust camber. Behind the upper control arm attachment point there are washers. You probably have three or four. Removing them is worth approx 1/4 degree per washer. Then, the lower control arms attachment points are fastened by eccentric bolts. So turning them will get you more or less camber.
This is true on the rear suspension as well.
That's one thing I like about the C5 and C6 Corvettes. With the camber/caster adjustments as well as the spring tip adjusters, you can really dial-in the car to your preferred driving style and usage.
Pfadt alighment
Got this done about 1000 miles from new and have never been happier. No abnormal tire wear on my Grand Sport.
http://www.pfadtracing.com/blog/wp-c...-9.12.2011.pdf
What do you recommend camber? I do not race my Vette so I don't
need a lot of camber. Do I go by the "Corvette Alignment Recommendations Performance Street" numbers?
Front min -0.7--max -0.9.
And what are the stock numbers?
Thanks again, Kliph
The street specs (0.85) will probably provide best tire life.
Stock specs are included on the David Farmer Alignment page, center of these numbers (0.75) would be the GM recommendation and close to the Phadt recommendation.
https://dl.dropboxusercontent.com/u/...ignment-C6.jpg
Hunter Engineering makes the best (and most fool proof...) alignment equipment so I usually look for a shop with one. The key is to find someone who cares enough to spend some extra time to align close to the center of spec.
Received 2,060 Likes
St. Jude Donor '13
Toe-IN makes the car more stable, and also tends to counteract the slight inner-edge wear that comes from negative camber. You want just a little, the Pfadt street specs are good except they have the + and - reversed; for most alignment machines toe-In as expressed as +.
Negative camber gives better cornering performance and modest amounts (1.0' or less) have little or no bad effect on tire wear. Again, Pfadt has good numbers.
Better Pfad sheet to print out and hand to the tech since there is no wiggle room.
http://www.pfadtracing.com/docs/camb...t-settings.pdf
My Chevy dealer is scurred. The manager got his alignment guy to come over and tell me why they cant legally change the alignment specs bla bla bla. Vandergriff Chevrolet. Can anyone recommend a place in Ft Worth/Arlington that could align to phadt specs? If not, I will just have to call around different shops and see.
Find a place that specializes in alignments, some local autocross or track guys can point you in the right direction. These popped up with a quick Google.
http://texastrackworks.com/
