Waxing question, Not about products.
Any time! just let me know
Former Vendor
Well let me clarify one thing about the orbital just in case so there is no confusion, the orbital that I have does not spin, its more of a one handed vibrating orbital, I know some orbital have spin speeds, as this one does not have a speed control and spins lightly as you move it across the surface of the car.
http://www.walmart.com/ip/Carrand-94...isher/16487511
As for wax, I have three, Mother's (Which I just used and wasnt impressed with the flaking that occurred during removal) Meguiars wax, and Zymol cleaner wax (like these two better). With the orbital I find I dont use as much wax and dont have that wax buildup in the creases from when doing it by hand.
I waxed the windows with these products as well as my headlights and tail lights, with no ill effects, but I also dont let them sit for very long either.
I would not use a traditional wax on glass and taillamps. I would suggest a coating designed for glass and a coating designed for lamps with a high UV protection. If you are looking for a cheap and very effective glass protectant, see if you can find Aquapel locally.
Waxing with the correct pads and products will not remove clear.
I use a DA polisher to apply LSP (last step products) as it produces the most even coverge while using the least mount of product. Great when you re detailing for $$ to save time and product
maybe i'm not up on all the current products out there.Just back in the day seemed anybody who didnt know how to handle a polisher was bringing in their cars for re-sprays.It seems that todays products have much less "cutting" power than the ole'rough and ready"lol,therefore i will reserve my comments and leave this to the "pro's".(however,and just mpop,I wouldn't take to a wheel(polisher,d.a,whatever) to a vette unless I was trying to correct an imperfection or it was a fresh paint job. (again to remove peel imperfs,etc,) JMOP.
weekends are best
Its meditation...http://www.eventsounds.com/wav/wax.wav
#33
I use Zymol and they don't recommend using any machine. In fact they don't recommend using an application pad for their Glaze. You just rub a bit in your hands and melt it into the finish Literally apply it on the surface with your hands.
Clif
Clif
#37
Former Vendor
http://www.autogeek.net/optimum-opti...t-coating.html
#38
Sent you a PM.
