Help me get rid of the hideous fender/tire gap
Just swapped out my rear tires to 285/30/19 nitto invos today, and i thought the side profile would be a little bit thicker but it looks pretty low profile. My car is at stock height so now i have an even bigger gap between the fender and tire. Looks kind of funny now. So should i just lower the car on stock bolts or swap out the tires? I found youtube videos on how to lower on stock bolts but it was a z06, should it be the same for a z51??
Lower it on stock bolts first, I have the exact same tire setup & also hated the wheel gap. Now my fronts areperfect with the fender & the rear are about three fingers away. If that doesn't do it for you, then lower on aftermarket bolts or do the mod to the stock ones, (but i would just buy aftermarket ones to have a double set just in case). Remember if you want to keep this setup, your new tires will be shredded without an alignment.
Why did you go to a smaller diaameter tire? the 285/30 is 1.12" shorter diameter than the 285/35 stock size.
Your fender gap is now .56" more than it was stock (and the car is .56" closer to the ground).
http://www.tacomaworld.com/forum/tirecalc.php
Use the chart on comparing sizes and find the closest tire diameter to stock that will fit your wheels.
You also have to keep in mind that the sizes from the charts are mostly guesswork, they are a calculation, not a measurement. There is no standard for tire measurements and it seem that every manufacturer has their own idea of how long a millimeter is.
Every tire size has a tolerance. Some manufacturers shoot for nominal, and others shoot for the bottom of the tolerance in order to save some money. But if you buy a different size, you generally get a different size.
