Sinking Corvette?!!?!
Roughly one year ago I decided to go with a set of HRE wheels at a local speed shop. In addition to the new wheels and tires, they also lowered my car on the stock bolts, which finished the look nicely, but I feel like the car is lower now than last summer! Is it possible the car is dropping gradually over time or is it my imagination? Has anyone else observed this occuring on their lowered corvettes?
Yes, it seems they all do, my father 2005 did and my 2009 with 18k on it has. I used to be able to put a jack under it with pucks to lift it, now I have to pull up a little on the fenders to get the jack under there.
Same here. 2008 Coupe. Quite surprised when my jack would no longer go under it. It's gotta be springs weakening and/or reduced gas pressure in the shocks. Tire wear, maybe. Yeah, ride height bolt pads could have issues too. A combination of all the above?
I really can't see your ride hight changing from worn springs, worn shocks, etc, I guess it could over a 10 year period or so but you would be talking tenths of a inch. My 08 has not change at all since I purchased it New.
.08 with 50k is still at lowered height with no change. Check your bolts.
No, I'm not worried about it. It's only maybe 1/4"....just enough to where my jack would no longer go under. I should buy a low-profile jack someday.
but i can tell you my car is def lower and it is bc i need new rubber all around...no question...
also dumb question but is the new tire the same size as the old one? is it same aspect ratio?
Received 2,886 Likes
When my pfadt sport shocks wore out I could tell my ride height was lower. Air dam scraped a lot more backing out of my driveway.
Put on Bilstein Sport shocks and all was good for 6 months. Now they have settled some so I am dragging a little more but not as much as before.
Shocks can affect ride height.
