steering feel
Old 07-24-2014, 09:45 AM
dcarter0001
dcarter0001's Avatar
Default steering feel
I've had my 05 for about 2.5 years and it has always seemed to have a tight steering feel when compared to other cars. But the most notable thing is that after turning a corner it doesn't straighten back up on it's own, you have to turn the wheel back to straight. Is this normal or not.
Old 07-24-2014, 09:52 AM
Boomer111
Boomer111's Avatar
Actually I believe the complaint was with the early C6 models (05-07) that the steering was to lose. I know in 08 they changed the steering feel making it a little tighter.
Think the wheel return has to do with the wide tires.
Others will know more.
Old 07-24-2014, 09:54 AM
Zachreligious
Zachreligious's Avatar
Wide tires and alignment. Do you know what your alignment on the front is now (camber, caster, toe)? Caster will be the biggest contributor.
Old 07-24-2014, 10:50 AM
61X
61X's Avatar
My first thought is that it needs more caster. Get it on an alignment rack and check it out.
Old 07-24-2014, 12:53 PM
dcarter0001
So it's not normal
Old 07-24-2014, 02:15 PM
Boomer111
Boomer111's Avatar
How are the tires wearing? Any scrubbing or uneven wear? This would indicate and possible alignment issue.
Old 07-24-2014, 04:28 PM
dcarter0001
car drives straight and no uneven tire wear.
Old 07-24-2014, 06:20 PM
Boomer111
Boomer111's Avatar
Have you checked the power steering fluid level?
To steering feel
Quick Reply: steering feel
