Radar Detector Power Down
3rd Gear
My 2007 Corvette is my first GM car and am installing a radar detector. All other cars that I have had I have been able to find something in the fuse panel that shuts off the detector when car is shut down. In my Vette, I have tried the radio fuse, as well as several other fuses that go "dark" when the car is turned off, but to no avail, the radar detector stays on. (How?) I have seen threads on here that posters just unplug or turn the radar detector off. No other options???? I am afraid I am going to forget to turn my detector off and drain the battery...
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I use one of these on my V1 simple...
http://www.ebay.com/itm/Valentine-One-MirrorWire-Radar-Detector-Hardwire-Power-Cable-V1-Radar-Laser-/191191944840?pt=US_Radar_Laser_Detectors&hash=item2c83ed8e88&vxp=mtr
Received 1,598 Likes
If you tap into the rearview mirror for power your detector will cycle on and off with the ignition. I use this setup on my Passport and it works great.
3rd Gear
unplug the harness to the mirror. the pink wire is + and the black wire is -. use a voltmeter to confirm. you will need to cut the harness to you detector.
make sure you double check the polarity at the plug going into the detector. I made my own for another car. I striped the wire folded it and slid it into the harness. I then used a zip tie to hold the wires together onto the mirror harness.
I used 1 drop of silicone on the radar bracket and stuck it to the glass, allowing it to dry overnight.
3rd Gear
Thanks Truckplay!!!!
