Need help installing the F55 shock simualtors
Received 2,062 Likes
Well good for you that you have lots of cash to waste, because the average person really does not need F55 at all. I don't notice a huge difference, and I have tons of cash left in my pocket. Why are you even in this thread if you are just going to bash a bunch of people who obviously have the desire to get rid of F55 and save money? That is what this thread is all about, don't you understand that??? It's our decision to do that, it's not an unsafe move, and it's not ridiculous at all.
If this was a road racing thread??? by all means, get some coil overs.. but these saving money threads are painful for a fanatical corvette fan.
Sorry Patman, you're right. but you are wrong about one thing... i do not have tons of cash in my pocket. i just don't want to remove a valuable option from my car and feel like when i see these threads that people as opposed to saving a few bucks up and buying the F55 shocks, rush out and grab the cheap ones. I feel bad that guys are doing this as i know it's not what they wanted (really)..
Figured out what happened! The two plugs to two of the shock solenoids were toasted, WTF . Service Ride Control and Max Speed 255 km/h messages don't seem to affect car. I am torn between buying a set of simulators or driving the car as it is - I will never go faster than 255 km/h (155 m/h) anyway.
I decided to give these simulator plugs a try. First drive was no issue and the next day my dash flash the same "service ride control" and "max speed 158 mph" warning messages when I start the car. Does not affect the car and I have not test the 158 mph limit ... nor will I ever reach that speed on the track unless I decide to break land speed record at Utah salt flat
I have not check the plugs and see if they are toast like yours and I suspect mine have suffered similar fate. It does not appear there is a easy solution to get rid of magnetic shocks and many newer corvette (2011+) have magnetic shock software in BCM unit that can not be easily "erased"
Where did you get those parts? Are they GM?
At what mileage did your shocks fail? Front shocks first or rears?
One would think the price of these shocks would go down since there are more cars on the road using this type
Shock did not fail. I have coilover. Magnetic shock and leaf spring could not hold up to track use. I got the zip simulator plugs from one of the vendor - not GM parts. Will take a detail look at the zip simulator plugs and return them if defective - not cheap at $199
That's still a ridiculous price though! I ended up paying $500 for FOUR practically brand new Z51 shocks, and that included the labor and an alignment and lowering too!
Why not just get a set of coilovers at that price? Would be much superior to the F55 system at the track with little difference on the street. GM needs to stop selling these things at such ridiculous prices!
#33
had a chance to inspect the simulator plugs and all the white end plugs to the magnetic shocks shown signs of overheat and one of them is so bad it melt the plastic at the end as shown below - this is after one quick 15 min drive. All the black color plugs are fine. Waiting to hear back from Zip to see if there is a fix
#34
FL Events Coordinator
Because Coilovers are NOT the same or superior to the F55 system. I actually drive my Vert....daily....and when I switch from tour to sport there is a BIG difference in the ride and handling....EXACTLY....as promised from GM. If and when they go bad .... I will replace them with OEM F55 shocks. And to those who deceide not to....thats fine as well. It's YOUR car and you can do what you like with it. IMHO.
#35
Won't the ride on public streets beat you up where you will feel every bump with coil overs? Tracks are ideal and perfect smooth roads unlike these pot hole streets. The F-55 will give a much better comfortable ride in day to day driving.
#36
I also saw (in the past) people reference a tech II to delete the messages.. When mine needed replacing a friend mentioned the simulators and although i am not made of money LAUGHED in his face..i for one bought my C6 BECAUSE of the F55 and could not imagine swapping them out.. even after replacing the expensive shocks.. It handles irregular surfaces so much better. i test drive both and on these roads around here? F55 is a must in a vette..
Is the "non F55 ride" in a GS like a Z51, especially on rough roads? Is F55 a really nice thing to have for the ride?
Thanks,
#37
Right now, I just need to reset the warning messages every 10 minutes.
#38
I got mine from ZIP too. I told ZIP the sims were toasted. ZIP was nice enough to send me a second set, but there were burned too. The sims are made by Casper's Electronics. I emailed the problem to Casper's. Got a reply saying they will look into it - never heard from them again. I will be very interested to see if you can find out the fix.
will keep you posted but I doubt Zip have solution for the issue esp if they are not the one that make the plugs
#39
Let me jump in here and ask a question(which has been covered before, I know!) I'm leaning heavily towards a '12 or 13 GS over a base and am concerned about a stiff ride( I had an '85 Z-51, very rough!!!)
Thanks,
Thanks,
#40
update, got hold of zip and they don't have a fix for the issue so they refund me fully. They are not made by zip I believe. Rich at Able Chevy was able to figure out ways to work with BCM unit so you can still have traction control options and install coilover. Contact Rich if you want to know the specifics
