not mine
Suspicious mind....if anyone wanted to get out of ownership of a car like this - it wouldn't be that much of a hard sell.
Received 3,660 Likes
2016 C6 of Year Finalist
Ummmm, what? Upon closer observation I duly noted the door is in the unopen position...which is kinda what I alluded to when I mentioned the recovery vehicle operator...ah, never mind. The door fried in place.
Diamond and Cirrus Aircraft are 99% Composite Material. Comprised of Glass Fiber Reinforced Plastic (GFRP or Fiberglass), Carbon Fiber Reinforced Plastic (CFRP or Carbon Fiber), Foam Core, and Kevlar. The only metal on a Diamond Aircraft is the Engine, Propeller, Engine Mounts, Engine Horse Collar and gear. The 'Firewall' is Fiberglass with a thin sheet of finger slicing .010" 301 1/4 Hard Stainless. Where the Spring Steel Gear Mounts to the Fuselage is Composite. As are all of the spars, bulkheads, longerons, fuselage, empenage, stabilizers, and flight control surfaces.
Damn, man, you are on it! And here I thot it was the chrome blingy stuff that focused the sun into a hotspot that flamed up.
