splash guards....again!
I just went through the whole comparing all available splash guards... And opted for the factory GM...they fit perfect look great and do their job for a little over a hundred bucks delivered to your door...
GM doesn't make OEM for the GS/Z06 gents....OP just don't got with the RPIs...horrible fitment on the set I had ordered. Also I'm interested to see if anyone is using the ones you mentioned.
I would be interested in a set too... I will follow this thread for some feed back and links for some SG's that fit and look good. I bought a pair of fronts from RPI and they fit awful and the poor fit makes the wheel wells look bad.
I bought Mid America last year for our 2013 GS. I believe they are RPI units. Fitment was not good. Later found out that Fitment is apparently a crapshoot with either Apsis or RPI's. Have since bought RPI's and will try again to put them on. I'm hopeful...
Glen
Glen
Apsis
I went with the Apsis splash guards about 3 years ago for my 2010 GS. The fitment was challenging but doable and they match the factory rears quite nicely. I know that they are costly however 10K miles and no stone chips anywhere on the body so I feel that it was money well spent.
I have the RPI splash guards. They look great. Fitment was an issue it took me 10 minutes per side not 5.
Note that the OP stated for the Z06 or GS. There are no GM front splash guards for the wide body 'vette's.
