Is there a trick to replacing the map light in the rearview mirror?
Old 06-11-2014, 01:44 PM
Scottys78
Scottys78's Avatar
Default Is there a trick to replacing the map light in the rearview mirror?
I can get the lens off no problem, but for the life of me cannot get the bulb out. I can't just pull it out because it's too difficult to get a grip on and gets too hot quickly. I've tried pliers and cannot get a grip them either. So try putting on a surgical glove to give me some grip but that didn't fare much better and I burned my fingers.
So enlighten me Corvette forum, please
Old 06-11-2014, 01:52 PM
Scottys78
Scottys78's Avatar
Well had one eureka moment that if I got in the car and close the door the bulb would go out and stop burning me but I still can't remove it
Old 06-11-2014, 02:23 PM
Ahmer
Ahmer's Avatar
Use a FLASHLIGHT! Plus I used rubber pliers.
Old 06-11-2014, 02:26 PM
McPeds
McPeds's Avatar
Make a loop with fishing line or other tiny string and lasso it out. That's how I changed mine to LED.
Old 06-11-2014, 02:31 PM
MRDOO
4th Gear
MRDOO's Avatar
needle nose vise grips
Old 06-11-2014, 02:32 PM
Jclgodale3
Jclgodale3's Avatar
I used needle nose pliers with a couple wraps of electrical tape on the tips...not worrying about them being "on"
Old 06-11-2014, 02:35 PM
Power Hawk
Power Hawk's Avatar
I replaced all of my interior bulbs with LED's a couple months ago. I was not able to get the old map lights out using the floss method or with rubber gloves. I just have that type of dumb luck on some things. However, I did remove them using needle nose vice grip pliers. Take your time and adjust them so that they grip the bulb with just enough pressure to remove old bulb. Good luck and let us know how it goes.
Old 06-11-2014, 02:44 PM
Scottys78
Scottys78's Avatar
Thank you guys
Tried using dental floss to lasso it but that didn't work
I ended up wrapping the needle nose pliers with the rubber glove I had and that ended up working.
I am now LED throughout
Eight lightbulbs took an hour
Old 06-11-2014, 02:50 PM
Power Hawk
Power Hawk's Avatar
I love the LED look. Congrats. It took me much longer to replace mine. I also replaced the back up lights with LED's. I put superbright LED's in the coves as well.
Old 06-11-2014, 03:16 PM
Scottys78
Scottys78's Avatar
Thanks I agree the LEDs are good look. The eight bulbs I did were the two reverse lights, rear interior cargo lights, rearview mirror map lights, and cabin floor lights.
Can anyone verify for me, before I take it apart, if the license plate bulbs are the same as the other interior bulbs?
Old 06-11-2014, 03:34 PM
EBvette02
EBvette02's Avatar
use a zip tie.
Old 06-11-2014, 03:45 PM
ptroxx
ptroxx's Avatar
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Originally Posted by EBvette02
use a zip tie.
Old 06-11-2014, 04:09 PM
Scottys78
Scottys78's Avatar
What I'd really like to know Can anyone verify for me, before I take it apart, if the license plate bulbs are the same as the other interior bulbs?
Old 06-11-2014, 04:13 PM
Power Hawk
Power Hawk's Avatar
Same as other interior bulbs (not same as rear hatch bulbs).
Old 06-11-2014, 04:31 PM
Scottys78
Scottys78's Avatar
Awesome thanks. i'm going to have to order two more bulbs
Old 06-11-2014, 04:39 PM
blittle
blittle's Avatar
As you can see, there are various ways......after trying a couple, I opted for this one: take a piece of duct tape , wrap it around the bulb leaving enough of a "tail" of tape to take a pair of needle nose pliers and pull on the tail......... worked perfectly, no sweat!
Old 06-11-2014, 08:14 PM
Jclgodale3
Jclgodale3's Avatar
Thank you guys
There ya go!
To Is there a trick to replacing the map light in the rearview mirror?
Old 06-12-2014, 07:54 AM
EVILFACE
EVILFACE's Avatar
Little strip of duct tape and pull....
Old 06-12-2014, 11:52 PM
pk5
pk5's Avatar
Just in case anyone decides to read this thread later, I tried all the above and still couldn't get it out. I eventually just resorted to beating it with pliers, breaking it into millions of pieces and just digging it out. Took a lot less time, for me at least, than trying all the other methods
Old 06-13-2014, 12:19 AM
Jclgodale3
Jclgodale3's Avatar
I think it's more about the solution...with the least chance of damaging things. Beating on anything electronic is a big chance most do not want to
take
Quick Reply: Is there a trick to replacing the map light in the rearview mirror?
