Help & opinions needed
05 c6 z51--slight modified
So when you first get in your corvette and start her up, the dash gauges go all the way across and come back then it starts. --Normal
Now while I'm driving and get on it a little and come to a stop at a light or a stop sign, I see the speedometer gauges doing that again going all the way across again. ---Not sure if its normal
What could this be and is it a problem?
Not normal but not sure what the problem is.
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
Not sure either, but like above I'd check starting in the electronics because it seems to be replicating a cold-start situation. I'd start w. battery cables, to starter motor and see if they're all tight and in good condition. Used to be something about steering column, too. Tell us what you find.
....good advice
Received 2,882 Likes
First time I have heard of this problem. It does sound like something is loose somewhere. Gage pod is easily removed so you could check the connector. GL and let us know what you find.
