Side skirt guys "step inside please" with pics
Guys and gals...I would be interested in seeing your c6 Z06/GR1/GS that you either installed the stock width ZR1 style sides skirts or the extended wider version side skirts on you cars. I've just received my front splitter and side skirts (wide version) ready to install on my wide body and and not sure the wide versions will compliment my car. I'm second guessing and debating going back to and reordering the stock narrower versions.
Can you post up pics of your cars that side skirts were added and tell me if you used the standard width version? Or the extended version? Also note if you are running a stock 19x12 rear wheel/tire setup? Or wider aftermarket wheel setup? Before I start drilling I just want to make sure these wider version don't give the bottom of my wide body the appearance of having wings under the doors. Please tell me everything about the wheel and skirt setup that you have with as many pictures as possible. It would be greatly appreciated and would determine whether I send these wide version back and order the stock ZR1 width skirts.
Received 1,013 Likes
2016 Corvette of Year
2015 C6 of Year Finalist
Thanks, I haven't had any issues with it being so low.....
But, south FL we don't have too many dips in the roads, I do have speed humps in my hood, not bad.
Thanks for removing the trash can, it wasn't trash day so I couldn't be bothered to move it haha
iv only had mine on since jan an almost need a new set already the driveways speed bumps an pot holes are killing me
