VERY LOUD NOISE FROM TVS Supercharger
Where is the oil fill plug for the TVS 2300 supercharger 2008 Z51, Have a leak or a bearing is going bad !! Very LOUD !!!! 30K MILES
If you have bearing noise, then you have needle bearings going south, and time to rebuild the unit (replace the bearings and seal).
noise in Supercharger , very loud wine !!!!
OK, Took off the rear supercharger belt and the loud noise went away, ,could belt have been too tight or is there a bearing problem !!!! Turned the other pulley by hand from which i took the belt off and hear no grinding or any noise what so ever, so one screw is turning and the other from which I removed the belt is not , what do you guys think the problem is ????
