Recall
Recall
Announced today:
RECALL #2: 2005-2007 Chevrolet Corvette
This recall of 111,889 U.S. vehicles is meant to fix a serious problem with the low-beam headlights. GM says that "When the engine is warm, the underhood electrical center housing could expand, causing the headlamp low-beam relay control circuit wire to bend slightly." Over time, the circuit wire can break, disabling the low-beam headlights.
This problem appears to affect Corvettes from the 2008-2013 model years, too, though GM says that those vehicles will be repaired via a Customer Satisfaction Program, rather than a full-fledged recall. As with recall #1, GM hasn't specified how it will fix the problem.
http://www.washingtonpost.com/cars/h...2c4_story.html
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
There is sticky all about the recall.
Announced today:
You mean announced last week!
By Richard Read | HighGearMedia.com, Published: May 15
Low beam recall is mentioned in the 3rd link of the first post in the sticky.
