Ceramic Brake Pads, what did I do wrong?
Replaced my stockers that had 22,000 miles on them, looked great by the way. They were squealers though so I spent the 100 bucks and bought the Hawk ceramic pads. Finished the install last night and did the break in procedure by the letter...no squealing. I was excited....went out today for my 25 mile cruise. The squealing is worse now!!
For the record, I only replaced the fronts, didn't think the rears were the problem.
I've read quite a few posts here of people who fixed their squealing issue by going ceramic so I'm stumped.
Help me out if you can.
When I changed the pads on my C6 at _102,000 miles_ they still had 30% on them.... changed them anyway.... brakes never squealed - ever - in the more than 126,000 miles and seven (7) years that I owned the car. In fact, none of my five Corvettes ever squealed in more than 600,000 miles. Wonder why some cars do it, others don't?
Been a few to over the 50 years of driving.
I am easy on brakes though, could that be a factor?
When my OEM pads are cold, they don't squeak. However, as soon as they warm up at all, then here comes the squeaking.
I don't know if you have manual or automatic (I have the A6), but I've found that if I throw the transmission into neutral, then I don't have the squeaking.
Steven
Steven
1. Do the break-in procedure again.
2. When I had mine installed the dealer said he 'burnished' them, but I did it on my way again anyway. Over the next week I was still getting noise, so I emailed the place I got them from and they told me they heard that sometimes it can take 150 to 200 miles for the squealing to go away-----they were right on the money.
3. Someone also told me that if the car sits for a long time (e.g., over the winter) the squeal may come back, but will go away if you burnish the pads again.
4. After the 175 to 200 mile mark I have not had a peep---even if the car sat for 6-12 weeks in the winter.
Be curious to know (1) which Hawk pads you have, and (2) if the above works for you.
Supporting Vendor
St. Jude Donor '11,'13
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Race Car Tech
You can buy small tubes of brake grease from any parts store.
I changed from OEM pads to OEM ceramics, didn't do anything to the rotors, put grease on the back of the pads where the 2 surfaces come in contact, and I bedded the brakes, and no squeals whatsoever.
The originals dd squeal from time to time. The originals still had 3/4 pad thickness when I changed them out for ceramics.
Received 2,093 Likes
I just installed powder coated calipers and Hawk ceramic pads (for low dust) last weekend. I was worried about squealing but that was not a problem on the old pads. I like you, followed all procedures to the letter during installation and break in. No problems. Make sure you put enough high temp grease on the rear of the pads. I did not do this when changing pads on my Dodge truck. They squealed like a stuck pig! They initially started to get loud after one day of driving. Good luck. Can be very annoying.
Retired & lovin' it!
Occasionally after a day of repeated low speed/easy/gentle stops my Hawk Ceramics will begin to squeal a bit.
Going through an abbreviated version of the bedding process quiets them down again.
Thanks for all the tips guys. I'll try the break in process again and hope the squeal goes away. I did use the provided anti-squeal lube that Hawk sends with their pads so that shouldn't be the issue. Also, someone had asked if I did anything to my rotors, answer is no. Does that affect anything?
