Doors not auto-unlocking
It's just two screws to remove the pad and a few more holding the two halves together...very easy.
I have been needing to do this for a while, mine stick once in a while.
When they they get stubborn and refuse to comply with my wishes to open the door, I've been using my Window Valet to lower the windows to reach in and open the door.
Probably take about as long to clean them up as it has taken to type this message! LOL !!
Thanks a bunch, you are sincerely appreciated!
Since the contacts are copper, if you actually see green corrosion, then use something to scrub a bit...if not, then WD should be fine. Houston is humid, so it might be a mess in there.
Changed fob battery today. No joy. Tried remote 2 for the heck of it. no joy either.
Doubt it's a corroded contact in the handle as it works fine if the car is unlocked...
and yes, there is a FOB antenna in the door. I saw it when I had the entire car apart for sound deadening 3 months ago.
After you rule that out, then try switching the antenna from the passenger door to the drivers door and see if that moves the problem to the other side. On this forum, it seems like there is sometimes a rush to start replacing parts before the problem has been isolated, so many of these parts are not needed. Because you have a problem that is exhibited on one side of the car but not on the other side, you have a good ability to isolate the problem and know more about what is causing it before you go buying new parts. The easy, simple place to start is the door pad switch...5 minutes at most. Then move on to a more difficult test....but start off easy and simple. Maybe you get lucky and maybe you don't.
sorry I haven't responded in a bit...we have exams this week so I've been concentrating on that.
I'll go ahead and swap the door pads and see if that swaps the issue.
If it does, quite frankly, I'll probably just leave the thing on the passenger side and not worry about it. It's not very often that I need to get into that side when the car's locked anyway.
I'll update with results.
swapped the door pads. no change. assuming it's an issue with the fob antenna inside the door. if I have time this weekend, I'll try and get in there to check the connections or swap sides.
