Minor brake issue after car wash...
Like most people, after I wash my car, ('13 GS), I dry it thoroughly.
If I run it around the community for a few minutes, and hit the brakes a few times before putting it in the garage, there's no issue.
The brake rotors are clean, shiny, and dry.
However, if I wash and dry the car, and drive it directly into the garage, the rotors will develop a film of rust very quickly. Of course this is to be expected.
What concerns me is the next time I go to use the car, (perhaps a day or two later), put the stick in reverse, lift the clutch pedal, and slowly start to back up, the wheels feel locked for a second, like the parking brake is on.
Then lifting the clutch further with a little more power the "seal" between the brake pads and rotors, caused by the rust, is broken with a snapping sound.
I don't imagine any damage is done, it just sounds nasty. Anyone else experience this?
Thanks...
Thanks...
Your E brake is a drums within the rear rotor's, not the pads that make contact to the rotor surfaces that the pad do.
Having said this, and the fact that your E brake C shape brake shoe may still be tight to the drums, could just be light rusting, dry, or not enough wear to the drum or shoes that is causing the slight binding as you disengage the E brake and move the car.
The drums and shoes will wear over time, and as they loosen up to each other, the problem should solve itself.
My '13 does the same thing. It's the e-brake. I usually pull it on lightly during the post-wash drive for 50-100 feet to warm the shoes and drum to get rid of the moisture. Occasionally, it'll also grab lightly when I'm backing out of the garage, then release.
Haven't noticed it on my Vette but my truck is another story. After it sits overnight after I have driven it in the rain, I really have to give it some gas and then the brakes "snap" loose. Just happened to me today.
I appreciate all the feedback.
I didn't know it was the e-brake since I fully released it before starting to move the car. At least I thought it was fully released.
Didn't realize it was the e-brake that was sticking, and not the pads, and rotors.
Live and learn. A thread like this doesn't attract as many posts as chrome vs. black wheels, but it's a lot more informative.
So...
But, it's good to know that it's a common issue, and doesn't cause any damage.
Thanks...
Thanks...
Ok what I`ve been doing is I clean and polish and wax my wheels then when I wash my car I cover my wheels with plastic trash bags so they don`t get wet same thing next time I wash the car cover the wheels I just go over the wheels with polish much easier than washing and drying and then dealing with the rotor rust .
