How do you remove the rim center caps?
I'm plastidipping my wheels this week and don't want to paint over the logo on the caps. No way I'm good enough to mask off that decal, but I can hand paint around it if it's off the wheel.
Anybody know how they come off?
Thanks,
Tom
Thanks,
Tom
What kind of rims? base C6 or GS? the GS just keep them on when you plasti dip them then you can take center caps off and with a razor just go along the groove of the logo and then peel off the plasti dip off the logo. Base C6 not sure which is easiest. But to get off the center caps off can take a thin knife or screw drive and pop them out or if you are taking the wheels off just pop them out when the wheel is off.
Not so easy: remove the wheels and pop the caps off from the inside, then clean the barrels while you have the wheels off.
If you use a knife to pry the caps off, you could scratch or damage the edges of the caps -- like I did. Jeez!
Received 1,498 Likes
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Is it possible to get dental floss behind the small opening?
Thanks for the help! It's the GS factory painted rims. I'll try the paint and scrape method and leave 'em on.
First time you might need something to pry with until you figure out how the clips work. After you know where to grip them they just pull off by putting your thumb down one lug hole and index finger down the adjacent hole and pull. Very easy once you figure it out. I take mine off several times a year during cleaning. You should ALWAYS pull them off BEFORE removing the wheel lugs to prevent the possibility of scratching them with the wrench.
I think the OP is talking about removing this style
Not this style?
One is usually popped out from behind with the wheel off and the other by hand or with a hooked tool.
Not this style?
Not sure exactly what rims you have, but on my stock '08 coupe, they just pop off with the help of a screw driver. They are held in place by friction. They should be easy to remove, then they snap into place when putting back on.
"2013 Grand Sport" with stock wheels pictured.
Received 2,093 Likes
This wheel pic is a plasti-dipped wheel
Post up some pics when you are done!
