Is there risk of damaging an automatic tranny by manual shifting on a '05 with Z51?
Old 04-18-2014, 02:32 AM
ammtzmtz
ammtzmtz's Avatar
Default Is there risk of damaging an automatic tranny by manual shifting on a '05 with Z51?
If there's something I wish the '05 had it's paddle shifters! Can I damage my tranny if I manually shift 1st-2nd-3rd-D? I saw another thread on this but it hit a dead end and left the answer unclear.
Old 04-18-2014, 07:31 AM
owc6
owc6's Avatar
Received 4,185 Likes on 2,679 Posts
I don't have a Z51 on my '05, but I always shift by hand (both up and down). So far no problems tranny-wise (knock-wood). She has 192,000 miles on her, and is going strong! As long as all the nannies are on, she shifts very smoothly, but it takes a split-second to do the shift. It's just a matter of practice so you can anticipate when the shift will occur. Without the nannies, it seems rough on the shift, though.
lisa
Old 04-18-2014, 09:12 AM
NoRuls
NoRuls's Avatar
I hate the paddle shift. Put the shifting back on the floor where it belongs!
Old 04-18-2014, 09:56 AM
dcarter0001
dcarter0001's Avatar
Hand shifting the A4 will not hurt anything. What will hurt is letting it shift to high gear at slow speed and then flooring it. It will shift to the lowest gear with a loud bang coming from the rear end.
Old 04-18-2014, 10:54 AM
ammtzmtz
ammtzmtz's Avatar
What would that bang be?
Old 04-18-2014, 10:58 AM
ammtzmtz
ammtzmtz's Avatar
lisa
Thank you! I appreciate you chiming in and sharing true experience! Many Vette drivers seem to speculate that there are definite risks and usually say "Don't Do It!... It'll damage the transmission!"
Old 04-18-2014, 11:14 AM
1rusty1
1rusty1's Avatar
Your differential and transmission sitting on the ground. The 05 A4 has a weak spot in the differential and when racing hard (wheel hop), owners have experienced failure. There are also many who have never lost the differential/transmission due to this. I’ve dropped into 1st rolling 20 or 25mph when merging on a long ramp, and it will pin you to your seat. I didn’t bust anything up but I don’t want to find out either so don't race it.
I have also read that others have driven their 05s hard and have never had an issue.
Old 04-18-2014, 11:18 AM
KX
KX's Avatar
How does the Z51 option have ANYTHING to do with how you shift? Do tell....!!
And in case you did not know: new brakes are cheaper than a new transmission!!
Old 04-18-2014, 11:22 AM
ammtzmtz
ammtzmtz's Avatar
I just gave the specifics of the car I own. Not using the manual shifting to stop, just on take off.
Old 04-18-2014, 11:28 AM
EVRose
EVRose's Avatar
The A4 does have a weaker differential case than A6 but its the '05 M6 that has problems with wheel hop. Not A4.
Old 04-18-2014, 11:38 AM
billyboy47
billyboy47's Avatar
St. Jude Donor '17
to each his own. i drove enough manuals in my life, time to relax now and enjoy paddle shifting without the clutch. only way i drive my car, paddle shifting. grrrrrrrrrreat!!
Old 04-18-2014, 01:16 PM
NoRuls
NoRuls's Avatar
I should have been more specific. I have an auto also but prefer to have the shifting on the floor.
Old 04-18-2014, 02:21 PM
Kenny94945
Kenny94945's Avatar
FWIW I manually shift my 05 A4 going so far as to blip the throttle to aid in smoothness.
Current mileage 35K no issues.
I have changed the trans oil at 10 and 25K miles and oil looked good w/ no visual contaminents.
Did this with my C4 and C5 also.
So...I have not add any issues by manually shifting an automatic trans in a Vette.
Old 04-18-2014, 02:36 PM
ammtzmtz
ammtzmtz's Avatar
Thank you for the response! I don't do it all the time but it's nice to do once in a while to get a bit more sound out of my Corsa Xtreme!
Old 04-18-2014, 05:40 PM
jimmie jam
jimmie jam's Avatar
I did it on two of my A4 C5's all the time. Should not be an issue at all,,,,
Old 04-18-2014, 09:06 PM
cclive
cclive's Avatar
Good, then it's fine. If you are constantly using the downshifting to slow the car when coming to a stop, it will wear out the transmission faster. As stated above, brake pads are far less expensive than transmissions.
Old 04-19-2014, 09:43 AM
ammtzmtz
ammtzmtz's Avatar
Great feedback everyone! I feel a little better about manually shifting my A4!
Old 04-20-2014, 03:32 PM
windyC6
windyC6's Avatar
The paddle shifters on these C-6"s, while a nice novelty, are just that, a novelty. They don't make the trannie shift any firmer than a normal auto with a stick in the console, or even on the column for that matter. Of course if your in the throttle at high RPM's then you'll get a harder, somewhat quicker shift, but it has nothing to do with the paddle shifters as its all an internal trannie thing. There are people that post that using the paddles is just the same as driving a manual.....HUM....never could figure that one out....LOL. Also, I would like to pass on to friends on why using an auto to often to slow down will wear out trannie faster ?? There must be some kind of explanation for this that I can pass on ?? I guess all those times I used the trannie in our truck to keep the pace slower while towing our boat on downhill grades through the mountains wasn't such a good idea ???
To Is there risk of damaging an automatic tranny by manual shifting on a '05 with Z51?
Quick Reply: Is there risk of damaging an automatic tranny by manual shifting on a '05 with Z51?
