wide body questions.
Old 04-17-2014, 07:45 PM
26sonic
26sonic's Avatar
Default wide body questions.
thinking of doing a wide body conversion to my 08 base car. probably going to do rear quarters and front bumper. saw that tko sells a front bumper z06 style for a base car and also sells rear qtrs anyone use them for there conversion or have a recommendation on who to buy from?
Old 04-17-2014, 08:46 PM
Stavesacre21
Stavesacre21's Avatar
I believe I've seen Gene from GMPartsHouse advertising all of the parts
Check out the thread here
Old 04-17-2014, 09:04 PM
Lerxst
Lerxst's Avatar
26 Sonic. Assuming (from your screen name) you must own one also? Probably a member of Offshoreonly?
Here's mine. Lookin as good as the day I had her custom built!
Sorry to get off topic.
Widebody conversion would look awesome.
Back to the (GO) Hawks game!!!
Old 04-17-2014, 09:18 PM
RLSebring
Supporting Vendor
Support Corvetteforum!
RLSebring's Avatar
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Go all the way, Not that much more.
I did mine and was going to piece it together thinking I could save some money. I checked with every vendor imaginable and went with Gene from GM Partshouse. Having everything in the box at one time saved me a lot of money overall.
I've seen a couple of Z front bumbers (one real cheap listed now) and I believe you can do a bumper delete on the kit and save a couple of hundred dollars.
If you work it you can save some money. When mine was painted the shop went by time and material on each panel and the Velocity Yellow matched perfect. I think the 2 stage paint was about 1400.00
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
Old 04-17-2014, 09:19 PM
26sonic
26sonic's Avatar
Lerxst very nice 26 sonic!!! I had a 1998 26 sonic but currentl own a 31 sonic with twin 496 ho's great great boat!!! so did you have a widebody kit done on your car? where did you purchase the parts and did you convert the whole car to a widebody (front , rear etc)?
Old 04-17-2014, 09:22 PM
myfunz
myfunz's Avatar
Ordered mine from RPI should be coming in soon painted.
Old 04-17-2014, 09:32 PM
ncvette_1FUNRIDE
ncvette_1FUNRIDE's Avatar
2015 C6 of the Year Finalist
First, my suggestion is to go with all OEM parts. Aftermarket is less expensive initially but most don't quite match the fit and finish of OEM.
I know from experience.
Also, I agree, do the whole conversion at once unless you are absolutely positive that you will never do the front. That's a lot less expensive to do than doing it halfway, twice. (or 3 times)
I know that from experience as well.
Start:
Middle:
OEM rear .....but aftermarket hood and front bumper (for narrow front).
Current:
RIGHT NOW:
In the shop right now getting OEM real Z06 fenders and an OEM 427 take off hood installed.
Old 04-17-2014, 09:37 PM
myfunz
myfunz's Avatar
Start:
Middle:
Current:
RIGHT NOW:
What made you change again, she looks pretty sweet.
Old 04-17-2014, 09:51 PM
ncvette_1FUNRIDE
I wanted to add ZR1 side skirts but the curvature of the aftermarket ZR1 fender is off just a little. They look good, but when I tried to add the side skirts there was a gap. The OEM Z06 fenders should solve that problem.
I could get by with the hood and it gets a lot of compliments, but I wanted a 427 carbon fiber take off hood while I they were still available.
And YES, I admit that I am nuts but after this change I am done.
That is why I advise the OP to go all OEM the first time.
Old 04-17-2014, 09:53 PM
Lerxst
Lerxst's Avatar
No. Mine is a brand new 2013 427 purchased new in Oct of last year. Only put 300 miles on her and then right to storage. I will tell you wide body is the only way to go. This car is wicked fast enough for me at 505hp & 475 ft lb torque.
Regarding our Sonic. When I had it built I had all the options put on 500 EFI, 8" extension, external steering, Gaffrig shifters, K planes everything. Sonics are great boats. Handle rough water very well. Rock solid hulls.
My goal is to end up with (once the wife and I retire) a 38' Cig.Top Gun and a Ford GT. No Kids (dinks).
Good luck with your conversion.
Hopefully our weather is turn soon here and I can driving the car annd boat!
Best.
S -
Boat motor.
Old 04-18-2014, 09:58 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
Thank you very kindly for the referrals. We would certainly be happy to help you out.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
To wide body questions.
Quick Reply: wide body questions.
