305/35/19 fit on stck c6 wheels??
Need some new rear tires on my stock c6 wheels, Will 305/35/19 fit ok or do i gotta do a 305/30/19??? And is 305 the widest i can go??
you want to stay with the 305/30/19 the 35 will make your T/C and ABS unhappy
305 is the widest youll want to run on a 10" wide wheel.
i run hankook ventus v12 on mine 305/30/19 car is low as possible and the wheels have 1/4" spacers to make them flush with the fenders/qaurters no rubbing , no problems
I had some 305/3019 Nitto Invos on my car in the past without any problems. The problem is that while there are tons of 305/30r19 tires out there, its pretty slim pickins for 305/35r19.
Smurfkiller, why would running the same height tire as stock, but wider cause any problems with ABS and TC?
It's not the same height as stock.
thats the problem i see alot people dont truly understand what the numbers meen.
305 width in millimeters/ 30 side wall height as percentage of the width of the tire/ ZR speed rating/ 19 wheel diameter.
so yes 35 is same number as stock tires but since these tires are 20mm wider its a greater percentage meaning the sidewall is taller.
305/30/19 26.3" diameter , 305/25/19 27.4 diameter , stock 285/35/19 26.8 diameter
hope this helps some of you understand
I just went through this and found that tires vary so much in actual width that I just said screw it and went with the stock sizes (plus it saved me about $350). I want different wheels any way so I'll get new tires then.
I think the safe rule of thumb is a 295 out back because tires vary physically in size.....one man's 305 is another man's 295.
Plenty of folks on here have ran 305's with no issues from what I gathered. I just got tired of comparing and calculating.
Tire Rack has some great info on tread width, wheel width and all that.
now you could certainly run a 305/35/19 on the rear, but either you would prob have to turn T/C off ever time you get in the car
or you could run a taller tire in front as well.
the ABS and T/C act up when you change the ratio of size difference between front and rear tires.
you change the height difference to much , you change the amount of revolutions per mile the wheel speed sensors then think the rear tires are spinning and start to activate the T/C or it thinks the front wheels are locking up and trys to activate the ABS.
very true which i still dont understand how can measurements vary? how wide is your tire , how is there not a standard way to measure this?
Thanks Smurfkiller, I completely forgot height was the ratio.
Why would going up 0.6" in diameter from stock mess up TC or ABS, but going down 0.6" in diameter from stock not?
1 Post
(Mine are stock sizes though)
Just got them last week, replaced some Michelin AS Plus RF's with the V-12's
you would think it would be the same , but i guess going smaller stays within the window of size difference allowed between front and rear and going larger puts it on the edge and could upset everything. im not 100% totally sure it will. i know before i changed mine i look and everyone was running 305/30/19 no probs so that what i went with.
you dont understand or own
The following 2 users liked this post by irok:
BigMonkey73 (11-21-2017),
STEFFENS (10-23-2015)
