High Quality ZR1 Style Carbon Fiber Spoilers & Side Skirts + Flaps
#245
Can you give me a quick lesson on how your products are made? I know vacuum infused is better than hand laid ( i think ), is there an even better method then vacuum? I
like your products and am looking to purchase them, but as any Vette owner would want, I'm looking for the best most reasonably priced product. Thanks and looking forward to doing business with you.
Gerry
Gerry
#246
Former Vendor
Gerry
Gerry
We Offer both the hand laid and vacuum infused versions. There is a different process which is more expensive in fact the most expensive carbon as well as the process. The carbon fiber is known as pre-preg (pre-impregnated) with partially cured epoxy to allow easy handling this is called B-Stage material and requires cold storage to prevent complete curing. B-Stage pre-preg is always stored in cooled areas since heat accelerates complete polymerization. Hence, composite structures built of pre-pregs will mostly require an oven or autoclave to cure. The process is just like the vacuum infused version except you don't have to infuse the epoxy since it is already impregnated with it, once you seal everything up and vacuum all the air out you have to cure them in ovens for hours.
This is the primo way of making parts.!!! That's how these paganis are made, Though vacuum infusion is the next best and way more affordable way.
Masterpiece.!!!
Gerdia (11-18-2015)
#250
Former Vendor
2010 GrandSport / Side Skirts and Flaps Only Cost?
#255
Former Vendor
Hello,
Fiberglass - $299 shipped
Hand laid Carbon Fiber - $599
Vacuum Infused Carbon Fiber - $699
We have them both in the OEM Size and the 1" Extended versions which are you interested in.?
#258
Former Vendor
If you have the mud flaps already then no you don't, if you do have the flaps which flaps are they OEM size or the extended version? The front splitter / side skirts I do have them both in fiberglass and carbon fiber and both OEM size and the extended version, the rear spoiler we only carry in fiberglass.
Vacuum Infused Carbon fiber front splitter / side skirts + flaps - $1150 shipped. W/ the fiberglass rear spoiler $1399.
Hand Laid Carbon fiber front splitter / side skirts + flaps - $949 shipped. W/ the fiberglass rear spoiler - $1199
Fiberglass front splitter / side skirts + flaps / rear spoiler - $799 shipped.
