They’re here! New Design Pricing Billet Tech Alternators
Supporting Vendor
The internal design is the same, great 6-phase stator, 12-pole rotor design.
The new case design is a one size fits all. It’s a one piece front case design vs. the previous three piece case, where the ears were pressed on. The designers have worked to create more space for aftermarket valve covers and place the pulley in a position where the factory serpentine belt length remains the same.
The black anodized cases in the previous design required a ground cable. That is no longer needed in this new design.
Many of us have grown tired of having under-performing alternators on our Corvettes. In the middle of the summer, pulling up to a stop light, radiator fans on high, A/C on high and we’re sometimes lucky to have enough voltage to keep the battery charged.
The factory Valeo alternator is rated at 140 amps in most cases, but that's a best-case and not a full-operating temperature scenario. At full temperature and at factory idle speeds, the factory alternator will only be able to offer 50-70 amps. When there is a great demand for power, the voltage suffers and that’s why you see the diminished voltage. The factory alternator is simply not an efficient design.
Billet-Tech has engineered alternator that eliminates ALL of these issues. They are designed using the latest and greatest in alternator design, which has greatly increased the low-RPM efficiency and output.
Here's what Billet Tech says about their design:
The 6 Phase Advantage
Billet-Tech alternators employ cutting edge alternator technology not found in other aftermarket alternators. 6 phase hairpin stators make Billet-Tech alternators fundamentally more efficient than other aftermarket alternators. This new technology and increased efficiency equates to incredible output at extremely low engine RPM, less energy wasted in the form of heat, and more horsepower to the wheels. Also, because less heat is being generated, the internal components of Billet-Tech alternators last longer. This is especially beneficial on turbocharged and/or endurance racing vehicles with high engine compartment temperatures. All Billet-Tech alternators feature soldered stator and rectifier connections, with epoxy re-enforced stator connections, reducing the chance of vibration failures.
Billet-Tech units are built exclusively with precision balanced low-mass rotors that allow them to operate safely at shaft speeds of 20,000+ rpm. This high RPM capability, combined with excellent output at idle, gives the user a much broader operating RPM range, and more flexibility in the size of the crankshaft pulley used. A properly selected Billet-Tech alternator can even fix low voltage problems caused by using small diameter, or "under-driven" pulley ratios. The higher pole count in the rotor also results in less electromagnetic interference to cause problems with radios and other electronics.
As a final precaution, Billet-Tech alternators are constructed with twin high efficiency cooling fans, and twin internal rectifier plates. While other high performance alternators have only one rectifier with 6 diodes, Billet-Tech units boast 12 press fit diodes with 300% more surface area to dissipate heat. These considerations to cooling airflow and heat dissipation make Billet-Tech high performance alternators the most durable aftermarket alternators you can buy. If you are experiencing premature alternator failure, intermittent electrical accessory problems, or low voltage at any engine RPM, a Billet-Tech 6 phase alternator is the answer!
"So what is there to gain from using the Billet-Tech alternator over the factory original?"
Better system voltage. "So what does better system voltage gain me?"
Many of the electrical components in our cars will perform better with full voltage.
Our ignition coils, fuel injectors, fuel pumps, cooling fans, electric water pumps, headlights (and the list goes on) will all perform better with better system voltage.
Why go with a Billet-Tech alternator over others? Take a good look at the cases of the competitors and you will notice that none of them have the beefy, stronger ears that Billet-Tech provides on their cases. Instead, you'll find some skinny ears with pins pressed in. These are modified cases, designed for another vehicle, modified to fit our cars and not nearly as strong.
4 finish options offered: Machined, black anodized, polished and chrome. * update: Machined and chrome are special order as of 08/28/2014
The Billet-Tech 170amp alternator will typically produce +1 volt and supply up to an additional 80 amps at full temperature, at idle speeds. In other words, the 170 will be more than enough to supply the Corvette with good voltage and have enough in reserve to support up to a 1500 watt stereo system.
Many of our members have purchased these and will agree that they are a vast performance improvement over the stock alternator.
These are actual pictures from my inventory.
I’m now stocking 170 amp polished and black anodized models only so they will be at your door sooner. When I have it in stock, I’ll ship your order within 2 business days. Machined and Chrome finishes are special order.
For payment by check: 500.00 for Machined, 525.00 for polished or black anodized and 560.00 for chrome.
Free shipping in the continental US for a limited time.
If your serpentine system is upgraded from the factory 6-rib to 8-rib, let me know because we'll need to make you a custom pulley for that at an additional cost.
If you have a "flip drive", "Secondary drive", "Direct drive" or any variant of it, you may need a shorter belt. The drives use a K060370
and K060365 or a Dayco 6PK915 or Goodyear 36" length belt are your shorter options.
Checks go to:
Bret Bradbury
12055 Saint Patricks Dr.
Forney, TX 75126
Add 3% for Paypal to blownblueZ06@gmail.com
Send me a PM and let me know payment is on the way, year make
About the warranty:
All Billet-Tech alternators are backed by a 10 year performance guarantee against manufacturers defect, by the manufacturer. Please visit http://www.billetalternator.com for more details.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Supporting Vendor
Supporting Vendor
Black anodized orders shipping to those of you that ordered early next week. Chrome cases still awaiting completion at the plating company.
Thanks for your orders!
Supporting Vendor
It's in the initial thread, but probably not so easy to find since there's so much in there.
Here's your pricing:
If you have a "flip drive", "Secondary drive", "Direct drive" or any variant of it, you'll need to get a shorter belt. The drives use a K060370
and you will most likely need to change to a K060365 or a Dayco 6PK915 or Goodyear 36" length belt will fit a little tighter.
Checks go to:
Bret Bradbury
Forney, TX 75126
Add 3% for Paypal
Send me a PM and let me know payment is on the way, year of your car and any significant details.
About the warranty:
All Billet-Tech alternators are backed by a 2 year performance guarantee against manufacturers defect. Please visit http://www.billetalternator.com for more details.
Checks go to:
Bret Bradbury
Forney, TX 75126
Add 3% for Paypal
About the warranty:
Supporting Vendor
It might be Tuesday or later before I'll be able to get to it. I've got a nasty week ahead.
Supporting Vendor
Due to the excellent response, I'm going to continue this sale for the members indefinitely. .
Thanks for your support!
Supporting Vendor
Thanks for all the orders guys!
Still have some of these in available.
Chrome units still on backorder but hoping they'll be available next week.
I received mine about a week ago and it is beautiful! It will go on this week with a new belt and a new battery and then I will hit the highway in my quest to find a new home.
It's nice to deal with a standup vendor and I would buy from him again without hesitation.
Received 2,897 Likes
Do these mount with the stock bolts?
I have a custom black chrome cover I want to reuse. If it will not fit I want to go black instead of machined.
Sent a pm yesterday but I guess you were busy enjoying your sat.
Money sent for machined alt for 07 LS2.
PM sent.
PM sent.
It does use stock bolts and wire harness. This is definitely NOT a part you will want to put any kind of cover over. It would be like keeping a sheet over a Rembrandt.
Supporting Vendor
Tracking # sent.
He's got a pretty wicked looking cover, so I'll have to let it slide.
